Im having some problems using the v2 API on foreman 1.4.2. I am trying to
add an override matcher to a smart class parameter. Everything works using
the foreman GUI but I get an error when I make this API call:
POST /api/smart_class_parameters/437/override_values (437 is the id of
the parameter)
POST DATA: {'override_value': {'match': 'environment=development',
'value': 'mynewval'}}
I have also tried sending this data as per the documentation:
"error": {"message":"undefined method `match' for nil:NilClass"}
Any ideas? Is this a bug? I'm updating other objects using the API without any problems.
On Wednesday, 2 April 2014 11:57:59 UTC+1, Jeff wrote:
> Hi All,
> the parameter)
> "override_value": {
> "match": "xyz=10",
> "value": "string"
> But the same error occurs:
> Thanks
> Jeff
I think you get this error if the parameters aren't found in the
request, so my guess is that you're missing the "Content-Type:
application/json" header.
On 02/04/14 11:57, Jeff wrote:
> Hi All,
> to add an override matcher to a smart class parameter. Everything works
> using the foreman GUI but I get an error when I make this API call:
> the parameter)
> "override_value": {
> "match": "xyz=10",
> "value": "string"
