Web application could not be started
Validation failed: Permissions Permissions must be of same resource type (ActiveRecord::RecordInvalid)
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:56:in save!' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/attribute_methods/dirty.rb:33:in
save!'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:246:in block in save!' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:295:in
block in with_transaction_returning_status'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:192:in transaction' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:208:in
transaction'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:293:in with_transaction_returning_status' /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:246:in
save!'
/usr/share/foreman/app/services/cache_manager.rb:13:in each' /usr/share/foreman/app/services/cache_manager.rb:13:in
create_new_filter_cache'
/usr/share/foreman/app/services/cache_manager.rb:20:in recache!' /usr/share/foreman/config/initializers/fix_cache.rb:9:in
<top (required)>'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:245:in load' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:245:in
block in load'
/opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:236:in load_dependency' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:245:in
load'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:588:in block (2 levels) in <class:Engine>' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:587:in
each'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:587:in block in <class:Engine>' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:30:in
instance_exec'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:30:in run' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:55:in
block in run_initializers'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:54:in each' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:54:in
run_initializers'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/application.rb:136:in initialize!' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
method_missing'
/usr/share/foreman/config/environment.rb:5:in <top (required)>' /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in
require'
/opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in require' config.ru:3:in
block in <main>'
/opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in instance_eval' /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in
initialize'
config.ru:1:in new' config.ru:1:in
<main>'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:105:in eval' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:105:in
preload_app'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:150:in <module:App>' /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:29:in
<module:PhusionPassenger>'
/usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:28:in `<main>'
Foreman was running without problems until this morning.
I have tried to upgrade to 1.10, but the result did not disappear
It has something todo with permissions, but i have no idea on witch file
Op vrijdag 30 oktober 2015 16:01:18 UTC+1 schreef Donovan De Beuckelaer:
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/validations.rb:56:in `save!'
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/attribute_methods/dirty.rb:33:in `save!'
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:246:in `block in save!'
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:295:in `block in with_transaction_returning_status'
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:192:in `transaction'
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:208:in `transaction'
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:293:in `with_transaction_returning_status'
> /opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/transactions.rb:246:in `save!'
> /usr/share/foreman/app/services/cache_manager.rb:13:in `each'
> /usr/share/foreman/app/services/cache_manager.rb:13:in `create_new_filter_cache'
> /usr/share/foreman/app/services/cache_manager.rb:20:in `recache!'
> /usr/share/foreman/config/initializers/fix_cache.rb:9:in `'
> /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:245:in `load'
> /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:245:in `block in load'
> /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:236:in `load_dependency'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:588:in `block (2 levels) in '
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:587:in `each'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:587:in `block in '
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:30:in `instance_exec'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:30:in `run'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:55:in `block in run_initializers'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:54:in `each'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/initializable.rb:54:in `run_initializers'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/application.rb:136:in `initialize!'
> /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in `method_missing'
> /usr/share/foreman/config/environment.rb:5:in `'
> /opt/rh/ruby193/root/usr/share/rubygems/rubygems/custom_require.rb:36:in `require'
> config.ru:3:in `block in '
> /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in `instance_eval'
> /opt/rh/ruby193/root/usr/share/gems/gems/rack-1.4.1/lib/rack/builder.rb:51:in `initialize'
> config.ru:1:in `new'
> config.ru:1:in `'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:105:in `eval'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:105:in `preload_app'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:150:in `'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:29:in `'
> /usr/lib/ruby/gems/1.8/gems/passenger-4.0.18/helper-scripts/rack-preloader.rb:28:in `'
Hi, have you managed to solve this? I'm facing the same problem:
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:79:in raise_record_invalid' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/validations.rb:43:in
save!'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/attribute_methods/dirty.rb:29:in save!' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:291:in
block in save!'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:351:in block in with_transaction_returning_status' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in
block in transaction'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/transaction.rb:184:in within_new_transaction' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in
transaction'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:220:in transaction' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:348:in
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/transactions.rb:291:in save!' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/relation/delegation.rb:46:in
each'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activerecord-4.2.5.1/lib/active_record/relation/delegation.rb:46:in each' /usr/share/foreman/app/services/cache_manager.rb:13:in
/usr/share/foreman/app/services/cache_manager.rb:20:in recache!' /usr/share/foreman/config/initializers/fix_cache.rb:10:in
<top (required)>'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:268:in load' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:268:in
block in load'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:240:in load_dependency' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/dependencies.rb:268:in
load'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:652:in block in load_config_initializer' /opt/rh/sclo-ror42/root/usr/share/gems/gems/activesupport-4.2.5.1/lib/active_support/notifications.rb:166:in
instrument'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:651:in load_config_initializer' /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:616:in
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:615:in each' /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/engine.rb:615:in
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:30:in instance_exec' /opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:30:in
run'
/opt/rh/sclo-ror42/root/usr/share/gems/gems/railties-4.2.5.1/lib/rails/initializable.rb:55:in `block in run_initializers'
Il giorno venerdì 30 ottobre 2015 16:04:20 UTC+1, Donovan De Beuckelaer ha
scritto:
>> config.ru:1:in `'
