I've had Foreman running for a while now (and it's awesome!) but am having
an issue with virtual machine deployment, in that there is no way of
setting defaults for virtual machines, either via the host groups or the
compute resources section. For example, when deploying to a KVM host, some
users need to use a specific bridge interface for the VM to come up on the
network correctly, but as there is no way of setting a default, they have
to manually select the correct interface whenever they deploy. This would
also be useful for the default CPU/RAM count for example.
Is there a way of setting defaults for virtual machines that I'm missing?
Andy
> Hi,
the initial Libvirt support actually had what you are asking for, but
since we moved to a multi provider impementation we still did not address
this properly.
the overall plan is to:
- remove hw defaults from hostgroups (old libvirt hypervisors)
- add a matrix of hostgroup <-> hw defaults (or minimum requirement) per
provider
- add all location specific info (such as subnet mapping to vm network
name)
1 and 2 can be done today, 3 is pending until our new multi location /
multi orgs / tenants work is merged, hopefully during the next couple of
weeks.
as workarounds, you can do a couple of things
- use the old hypervisors code, they would allow you to have a default
hypervisor and vm attributes per hostgroup
- change the xml templates we use (they would be found under your fog gem
inside lib/libvirt/model/compute/templates
- use the pull request patch which only sets the default network (only
valid for debian).
thanks,
Ohad
On Thu, Oct 25, 2012 at 5:33 PM, Andy Taylor wrote:
Andy
"Foreman users" group.
To view this discussion on the web visit
https://groups.google.com/d/msg/foreman-users/-/E6VxX9htNNsJ.
Hi Ohad,
Thank you very much for the detailed reply, that's very helpful.
Thanks!
Andy
On Sunday, 28 October 2012 08:02:13 UTC, ohad wrote:
> On Thu, Oct 25, 2012 at 5:33 PM, Andy Taylor <andyta...@gmail.com > > wrote:
>> Hi,
>> having an issue with virtual machine deployment, in that there is no way of
> this properly.
> 1. remove hw defaults from hostgroups (old libvirt hypervisors)
> 2. add a matrix of hostgroup <-> hw defaults (or minimum requirement) per
> provider
> 3. add all location specific info (such as subnet mapping to vm network
> name)
> weeks.
> 1. use the old hypervisors code, they would allow you to have a default
> 2. change the xml templates we use (they would be found under your fog gem
> 3. use the pull request patch which only sets the default network (only
> valid for debian).
> thanks,
> Ohad
>> Thanks,
>> Andy
>> foreman-user...@googlegroups.com .
