From a fresh CentOS 6 installation, all modules seem to be installed
correctly, but when trying to use the hammer_cli_katello commands, they are
not available. I can see the hammer foreman commands, but not the ones from
katello.
A while ago I created a script to install and configure a katello server
from scratch from the GIT repositories. There are no errors on the
execution and I don't know where to look at. Here is the script:
*# Start with a fresh install of CentOS *yum -y update
yum install -y git ruby rubygems
*# Install Installer *
git clone https://github.com/Katello/katello-deploy.git
cd katello-deploy
./setup.rb centos6 --skip-installer
*# Run Installer *
katello-installer --foreman-admin-password="changeme"
–foreman-authentication=true --capsule-tftp=true
–capsule-tftp-servername="10.10.10.10" --capsule-dhcp=true
–capsule-dhcp-gateway="10.10.10.10" --capsule-dhcp-interface="eth1"
–capsule-dhcp-range="10.10.10.20 10.10.10.200" --capsule-dns=true
–capsule-dns-forwarders "10.10.10.10" --capsule-dns-interface="eth1"
–capsule-dns-reverse="10.10.10.in-addr.arpa" --capsule-dns-zone "hq.ltg"
*# Here is the error.*After installing, the following command gives the
hammer cli katello error:
hammer -u admin -p changeme organization create --name Test_Cloud7
–description "Cloud Servers in VM internal network"
Warning: An error occured while loading module hammer_cli_katello
And here is the copy of the logs:
[root@satellite ~]# hammer -d log
[ INFO 2014-08-07 12:08:18 Init] Initialization of Hammer CLI (0.1.1) has
started…
[DEBUG 2014-08-07 12:08:18 Init] Running at ruby 1.8.7-p352
[ INFO 2014-08-07 12:08:18 Init] Configuration from the file
/etc/hammer/cli_config.yml has been loaded
/etc/hammer/cli.modules.d/foreman.yml has been loaded
/etc/hammer/cli.modules.d/katello.yml has been loaded
[DEBUG 2014-08-07 12:08:19 Connection] Registered: foreman
[Foreman] username: admin
[Foreman] password for admin:
[DEBUG 2014-08-07 12:08:24 API] Global headers: {
"Accept-Language" => "en",
:content_type => "application/json",
:accept => "application/json;version=2"
[ INFO 2014-08-07 12:08:25 Modules] Extension module hammer_cli_foreman
(0.1.1) loaded
[ERROR 2014-08-07 12:08:25 Modules] Error while loading module
hammer_cli_katello
[ERROR 2014-08-07 12:08:25 Modules] <NoMethodError> undefined method
`lazy_subcommand' for HammerCLI::MainCommand:Class
/usr/lib/ruby/gems/1.8/gems/hammer_cli_katello-0.0.4/lib/hammer_cli_katello.rb:27
/usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:36:in
gem_original_require' /usr/lib/ruby/site_ruby/1.8/rubygems/custom_require.rb:36:in
require'
/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/lib/hammer_cli/modules.rb:60:in
require_module' /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/lib/hammer_cli/modules.rb:39:in
load!'
/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/lib/hammer_cli/modules.rb:54:in
load' /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/lib/hammer_cli/modules.rb:65:in
load_all'
/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/lib/hammer_cli/modules.rb:64:in
each' /usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/lib/hammer_cli/modules.rb:64:in
load_all'
/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/bin/hammer:93
/usr/bin/hammer:19:in `load'
/usr/bin/hammer:19
[DEBUG 2014-08-07 12:08:25 Init] Using locale 'en'
[DEBUG 2014-08-07 12:08:25 Init] 'mo' files for locale domain 'hammer-cli'
loaded from '/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/locale'
'hammer-cli-foreman' loaded from
'/usr/lib/ruby/gems/1.8/gems/hammer_cli_foreman-0.1.1/locale'
'hammer-cli-katello' loaded from
'/usr/lib/ruby/gems/1.8/gems/hammer_cli_katello-0.0.4/locale'
[ INFO 2014-08-07 12:08:25 HammerCLI::MainCommand] Called with options:
{"option_debug"=>true}
[ERROR 2014-08-07 12:08:25 Exception] Error: No such sub-command 'log'
See: 'hammer --help'
Clamp::UsageError (No such sub-command 'log'):
/usr/lib/ruby/gems/1.8/gems/clamp-0.6.2/lib/clamp/subcommand/execution.rb:28:in
find_subcommand_class' /usr/lib/ruby/gems/1.8/gems/clamp-0.6.2/lib/clamp/subcommand/execution.rb:17:in
instatiate_subcommand'
/usr/lib/ruby/gems/1.8/gems/clamp-0.6.2/lib/clamp/subcommand/execution.rb:10:in
execute' /usr/lib/ruby/gems/1.8/gems/clamp-0.6.2/lib/clamp/command.rb:67:in
run'
/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/lib/hammer_cli/./apipie/…/abstract.rb:22:in
run' /usr/lib/ruby/gems/1.8/gems/clamp-0.6.2/lib/clamp/command.rb:125:in
run'
/usr/lib/ruby/gems/1.8/gems/hammer_cli-0.1.1/bin/hammer:106
/usr/bin/hammer:19
[root@satellite ~]#
IB
