I am wondering if there is a way to control the bindings of foreman-proxy?
I apologize for posting in this group, but after checking IRC and the
User's group, I am unable to locate the answer to this one.
I ran foreman-installer and got bit by the 422 register.pp error. After
some inspection, it appears foreman-proxy is running but is bound to the
localhost on 8443 and is not listening at all on the public IP 8443.
Trying to register the proxy manually gives a certificate does not match
hostname error…
this is a fresh install on Cent 7 minimal w/ an existing puppet master
configured w/ passenger. This is the latest version from epel of foreman
and the installer.
I appreciate the response - can you refresh my memory? was it on IRC?
This still is not functioning - not sure where to set the bindings for
foreman-proxy. I could solve this if I could manually set the bindings to
something other than localhost.
thanks!
On Saturday, April 18, 2015 at 3:29:24 PM UTC-4, Lukas Zapletal wrote:
> > Any help is appreciated!!!
> Responded already. Note this was added recently, I think in 1.7 or 1.8.
> Later,
> Lukas #lzap Zapletal
Please disregard – thank you for your reply – sorry for the crosspost!
It was the multiple versions of rack causing foreman not to listen on the
public IP.
thanks again!
> thanks!
>> Later,
