Dear foreman community,
I upgraded my old 1.12 foreman to 1.13, and then to 1.14 and then to 1.15.
Upgrade process worked well as documented and I am able to manage and
provision hosts with each upgrade.
However with the last upgrade from 1.14 to 1.15, I am able to provision the
host fine, but after final reboot, the vm PXE boots and starts installing
OS again.
I tried searching this forum but did not find any reference to the issue. I
saw some references to changing the boot order and modifying libvirt.rb but
my libvirt.rb has hd as the only option.
Any pointer/ assistance will be greatly appreciated.
Shri
check that you call the right built url within your install, that changed:
Greetings,
Klaas Demter
ATIX - The Linux & Open Source Company
----- Ursprüngliche Mail -----
Von: "Shrirang Alulkar"
An: "Foreman users"
Gesendet: Dienstag, 1. August 2017 22:23:08
Betreff: [foreman-users] weird upgrade issue - vm pxe boots again and again after successful installation
OS again.
Shri
Thanks Klass,
That was the problem. As a matter of fact the problem is well documented
here
(https://groups.google.com/forum/#!msg/foreman-users/IuvPJqeIpMM/g1Z2018WBAAJ)
To summarize the fix:
The kickstart template creates a KS file in /var/lib/tftpboot/pxelinux.cfg/
dir with the file name HEX IP (?) of the system being built.
Then once the KS process is complete the KS process has an API call to let
foreman know that it has finished building.
The default call is like this: wget -q -O /dev/null --no-check-certificate
<%= foreman_url %>
I changed it to : wget -q -O /dev/null
–no-check-certificate <%= foreman_url*('built')* %>
That fixed the issue. I am sure that the default 1.15 provisioning template
accounts for this but the upgrade does not.
The issue is resolved.
Cheers
Shri
> https://github.com/theforeman/community-templates/blob/1.15-stable/provisioning_templates/provision/kickstart_rhel_default.erb#L171
> Greetings,
> Klaas Demter
> Von: "Shrirang Alulkar" <shrirang...@gmail.com >
> An: "Foreman users" <forema...@googlegroups.com >
> the
> OS again.
> I
> but
> Thanks,
> Shri
> "Foreman users" group.
> email to foreman-user...@googlegroups.com .
> To post to this group, send email to forema...@googlegroups.com
