When edit host undefined method `datepicker_f' for #<ActionView::Base:0x0000000093d758>
Rubocop not loaded.
2023-03-03T15:41:54 [I|app|8d296430] Started GET "/hosts/srv.domain.local/edit" for 10.251.217.170 at 2023-03-03 15:41:54 +0100
2023-03-03T15:41:54 [I|app|8d296430] Processing by HostsController#edit as HTML
2023-03-03T15:41:54 [I|app|8d296430]   Parameters: {"id"=>"srv.domain.local"}
2023-03-03T15:41:54 [I|app|8d296430]   Rendered hosts/edit.html.erb within layouts/application (Duration: 326.3ms | Allocations: 272117)
2023-03-03T15:41:54 [I|app|8d296430]   Rendered layout layouts/application.html.erb (Duration: 326.5ms | Allocations: 272172)
2023-03-03T15:41:54 [W|app|8d296430] undefined method `datepicker_f' for #<ActionView::Base:0x0000000093d758>
 8d296430 | Did you mean?  datetime_f
2023-03-03T15:41:54 [I|app|8d296430] Backtrace for 'undefined method `datepicker_f' for #<ActionView::Base:0x0000000093d758>
 8d296430 | Did you mean?  datetime_f' error (ActionView::Template::Error): undefined method `datepicker_f' for #<ActionView::Base:0x0000000093d758>
 8d296430 | /usr/share/foreman/app/views/hosts/_form.html.erb:154:in `block (2 levels) in _cebc4f1606ffb7b0f560e8022b2da48c'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/helpers/capture_helper.rb:45:in `block in capture'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/helpers/capture_helper.rb:209:in `with_output_buffer'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/helpers/capture_helper.rb:45:in `capture'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/helpers/form_helper.rb:450:in `form_for'
 8d296430 | /usr/share/foreman/app/helpers/form_helper.rb:287:in `form_for'
 8d296430 | /usr/share/foreman/app/views/hosts/_form.html.erb:7:in `block in _cebc4f1606ffb7b0f560e8022b2da48c'
 8d296430 | /usr/share/foreman/app/models/taxonomy.rb:80:in `block (2 levels) in as_taxonomy'
 8d296430 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:195:in `as_location'
 8d296430 | /usr/share/foreman/app/models/taxonomy.rb:79:in `block in as_taxonomy'
 8d296430 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:154:in `as_org'
 8d296430 | /usr/share/foreman/app/models/taxonomy.rb:78:in `as_taxonomy'
 8d296430 | /usr/share/foreman/app/views/hosts/_form.html.erb:6:in `_cebc4f1606ffb7b0f560e8022b2da48c'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/base.rb:247:in `public_send'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/base.rb:247:in `_run'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/template.rb:154:in `block in render'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/notifications.rb:205:in `instrument'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/template.rb:345:in `instrument_render_template'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/template.rb:152:in `render'
 8d296430 | /usr/share/gems/gems/deface-1.5.3/lib/deface/action_view_extensions.rb:43:in `render'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/partial_renderer.rb:285:in `block in render_partial_template'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/notifications.rb:203:in `block in instrument'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/notifications.rb:203:in `instrument'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/partial_renderer.rb:280:in `render_partial_template'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/partial_renderer.rb:271:in `render'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/renderer.rb:81:in `render_partial_to_object'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/renderer.rb:27:in `render_to_object'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/renderer.rb:22:in `render'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/helpers/rendering_helper.rb:38:in `block in render'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/base.rb:273:in `in_rendering_context'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/helpers/rendering_helper.rb:34:in `render'
 8d296430 | /usr/share/foreman/app/views/hosts/edit.html.erb:13:in `_7159b3e38ad1d80fcf80a2bfcb1620e9'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/template_renderer.rb:61:in `block (2 levels) in render_template'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/template_renderer.rb:56:in `block in render_template'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/template_renderer.rb:71:in `block in render_with_layout'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/template_renderer.rb:70:in `render_with_layout'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/template_renderer.rb:55:in `render_template'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/template_renderer.rb:11:in `render'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/renderer/renderer.rb:29:in `render_to_object'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/rendering.rb:117:in `block in _render_template'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/rendering.rb:116:in `_render_template'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/streaming.rb:218:in `_render_template'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/rendering.rb:103:in `render_to_body'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/abstract_controller/rendering.rb:25:in `render'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/rendering.rb:36:in `render'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/instrumentation.rb:46:in `block (2 levels) in render'
 8d296430 | /usr/share/ruby/benchmark.rb:308:in `realtime'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/core_ext/benchmark.rb:14:in `ms'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/instrumentation.rb:46:in `block in render'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/instrumentation.rb:86:in `cleanup_view_runtime'
 8d296430 | /usr/share/gems/gems/activerecord-6.1.7/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/instrumentation.rb:45:in `render'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/implicit_render.rb:35:in `default_render'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `block in send_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `tap'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/abstract_controller/base.rb:228:in `process_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/rendering.rb:30:in `process_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
 8d296430 | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
 8d296430 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
 8d296430 | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
 8d296430 | /usr/share/gems/gems/audited-5.0.2/lib/audited/sweeper.rb:16:in `around'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/callbacks.rb:137:in `run_callbacks'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/abstract_controller/callbacks.rb:41:in `process_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/rescue.rb:22:in `process_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
 8d296430 | /usr/share/gems/gems/activerecord-6.1.7/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/abstract_controller/base.rb:165:in `process'
 8d296430 | /usr/share/gems/gems/actionview-6.1.7/lib/action_view/rendering.rb:39:in `process'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal.rb:190:in `dispatch'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_controller/metal.rb:254:in `dispatch'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/routing/route_set.rb:33:in `serve'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/journey/router.rb:50:in `block in serve'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/journey/router.rb:32:in `each'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/journey/router.rb:32:in `serve'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/routing/route_set.rb:842:in `call'
 8d296430 | /usr/share/gems/gems/katello-4.7.3/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
 8d296430 | /usr/share/gems/gems/katello-4.7.3/lib/katello/middleware/event_daemon.rb:10:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/static.rb:24:in `call'
 8d296430 | /usr/share/gems/gems/apipie-dsl-2.5.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
 8d296430 | /usr/share/gems/gems/apipie-rails-0.8.2/lib/apipie/static_dispatcher.rb:68:in `call'
 8d296430 | /usr/share/gems/gems/apipie-rails-0.8.2/lib/apipie/extractor/recorder.rb:137:in `call'
 8d296430 | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
 8d296430 | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
 8d296430 | /usr/share/gems/gems/apipie-rails-0.8.2/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/tempfile_reaper.rb:15:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/etag.rb:27:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/conditional_get.rb:27:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/head.rb:12:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/http/content_security_policy.rb:19:in `call'
 8d296430 | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/session/abstract/id.rb:266:in `context'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/session/abstract/id.rb:260:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/cookies.rb:689:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/callbacks.rb:98:in `run_callbacks'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
 8d296430 | /usr/share/gems/gems/railties-6.1.7/lib/rails/rack/logger.rb:37:in `call_app'
 8d296430 | /usr/share/gems/gems/railties-6.1.7/lib/rails/rack/logger.rb:28:in `call'
 8d296430 | /usr/share/gems/gems/sprockets-rails-3.4.2/lib/sprockets/rails/quiet_assets.rb:13:in `call'
 8d296430 | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/request_id.rb:26:in `call'
 8d296430 | /usr/share/gems/gems/katello-4.7.3/lib/katello/prevent_json_parsing.rb:12:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/method_override.rb:24:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/runtime.rb:22:in `call'
 8d296430 | /usr/share/gems/gems/activesupport-6.1.7/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/executor.rb:14:in `call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/sendfile.rb:110:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/ssl.rb:77:in `call'
 8d296430 | /usr/share/gems/gems/actionpack-6.1.7/lib/action_dispatch/middleware/host_authorization.rb:142:in `call'
 8d296430 | /usr/share/gems/gems/secure_headers-6.5.0/lib/secure_headers/middleware.rb:11:in `call'
 8d296430 | /usr/share/gems/gems/railties-6.1.7/lib/rails/engine.rb:539:in `call'
 8d296430 | /usr/share/gems/gems/railties-6.1.7/lib/rails/railtie.rb:207:in `public_send'
 8d296430 | /usr/share/gems/gems/railties-6.1.7/lib/rails/railtie.rb:207:in `method_missing'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:74:in `block in call'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:58:in `each'
 8d296430 | /usr/share/gems/gems/rack-2.2.4/lib/rack/urlmap.rb:58:in `call'
 8d296430 | /usr/share/gems/gems/puma-5.6.5/lib/puma/configuration.rb:252:in `call'
 8d296430 | /usr/share/gems/gems/puma-5.6.5/lib/puma/request.rb:77:in `block in handle_request'
 8d296430 | /usr/share/gems/gems/puma-5.6.5/lib/puma/thread_pool.rb:340:in `with_force_shutdown'
 8d296430 | /usr/share/gems/gems/puma-5.6.5/lib/puma/request.rb:76:in `handle_request'
 8d296430 | /usr/share/gems/gems/puma-5.6.5/lib/puma/server.rb:443:in `process_client'
 8d296430 | /usr/share/gems/gems/puma-5.6.5/lib/puma/thread_pool.rb:147:in `block in spawn_thread'
 8d296430 | /usr/share/gems/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2023-03-03T15:41:54 [I|app|8d296430]   Rendered common/500.html.erb within layouts/application (Duration: 4.5ms | Allocations: 7642)
2023-03-03T15:41:54 [I|app|8d296430]   Rendered layouts/base.html.erb (Duration: 5.8ms | Allocations: 10599)
2023-03-03T15:41:54 [I|app|8d296430]   Rendered layout layouts/application.html.erb (Duration: 16.1ms | Allocations: 31156)
2023-03-03T15:41:54 [I|app|8d296430] Completed 500 Internal Server Error in 375ms (Views: 16.6ms | ActiveRecord: 18.7ms | Allocations: 317541)
Foreman version: 3.5.1
Plugins:
  • foreman-tasks 7.1.1
  • foreman_acd 0.9.3
  • foreman_ansible 10.4.1
  • foreman_azure_rm 2.2.7
  • foreman_bootdisk 21.0.3
  • foreman_column_view 0.4.0
  • foreman_discovery 22.0.2
  • foreman_expire_hosts 8.0.0
  • foreman_hooks 0.3.17
  • foreman_host_reports 1.0.2
  • foreman_kubevirt 0.1.9
  • foreman_leapp 0.1.13
  • foreman_openscap 5.2.2
  • foreman_remote_execution 8.2.0
  • foreman_setup 8.0.1
  • foreman_snapshot_management 2.0.3
  • foreman_statistics 2.0.1
  • foreman_templates 9.3.0
  • foreman_webhooks 3.0.5
  • katello 4.7.3
Is this perhaps Forman_expire_hosts on a new Foreman(3.4) installation it trows an error: undefined method `datepicker_f' for · Issue #69 · theforeman/foreman_expire_hosts · GitHub ?
I have to disable it because there is no update in RPM
I have released expire_hosts 8.1.0 and pushed it to the repos for 3.4+, enjoy!
