I'm just in the process of setting up my first Foreman system to test
with, and it's looking really nice so far… a couple of questions
though:
Is there any way to have the smart-proxy register hosts? In my own
home-brew system, the default DHCP settings direct an unknown host to
a pxelinux file and centos ks file where all that happens is the post
script runs dmidecode, and fetches a URL to register itself with the
build system, then keep trying to wait for confirmation that there's
now a valid config for the host. Is there something similar with
Foreman? I guess with the REST API I could modify my existing setup,
but it'd be cool if there's already a little floppy image for this…
(also, how would a default DHCP setup like that play with Foreman's
own DHCP changes?) - So it'd be a little client that registers the MAC
address and hardware info, copying the rest of the information from a
template host. It just saves collecting all those MAC addresses
manually
Why do hosts AND hostgroups have an environment? What will happen
if they are set differently? Why can't I just have the host inherit
it's environment from the host group? Or am I misunderstanding the
distinction? I have 3 environments, and so far I've been creating sets
of 3 hostgroups - dev, test, prod - for each actual function/location/
customer grouping. This does feel a bit wrong.
Thanks in advance for any pointers from the old hands…
Howie
> though:
Welcome aboard
> 1) Is there any way to have the smart-proxy register hosts? In my own
> manually
That is Feature #983: Need 3 state support in tftp and build management - Foreman, we would love to get support for
that built in foreman itself.
> 2) Why do hosts AND hostgroups have an environment? What will happen
I think the environment in the hostgroups is used for:
- making sure that you see only the modules/classes the belongs to a
specific environment.
- as a default place holder for a host.
You can change the host environment if you wish (same like other attributes)
but the hostgroup is kind of a way to set defaults.
Howie
"Foreman users" group.
