Wrong installation package for Debian wheezy
I just tried to install Foreman on a new host.
It seems there is an error in the debian repository.
If I try to install foreman I get version 1.5.0-rc2. A check in the
releases files
on http://deb.theforeman.org/dists/wheezy/1.5/binary-amd64/Packages
confirms that.
Markus
Thanks for the heads up, Markus. The deb repos have been a bit
unstable for the last week or so, but thanls to you tipping me off,
I;ve finally found the root cause, so hopefully it should all settle
down now.
I can see 1.5.2-1 in the repos again, so you should be all set :slight_smile:
Greg
··· On 6 August 2014 18:48, hirnschmalz wrote: > I just tried to install Foreman on a new host. > It seems there is an error in the debian repository. > If I try to install foreman I get version 1.5.0-rc2. A check in the releases > files on http://deb.theforeman.org/dists/wheezy/1.5/binary-amd64/Packages > confirms that. > > Markus
Hi Greg,
thank you for fixing it. Now everything works like charm
··· > unstable for the last week or so, but thanls to you tipping me off, > I;ve finally found the root cause, so hopefully it should all settle > down now. > > I can see 1.5.2-1 in the repos again, so you should be all set :) > > Thanks, > Greg >
