Which version of Puppet are you using, on which OS?
On 18/03/13 10:06, james.osbourn@gmail.com wrote: > After running the command > > ruby /usr/share/foreman-installer/generate_answers.rb > > I select teh configuration options and save and exit and select to run > pupper with these settings and I get the following error > > Do you want to run Puppet now with these settings? (y/n) > y > wrong number of arguments (2 for 1) at > /usr/share/foreman-installer/foreman_installer/manifests/yaml_to_class.pp:23 > on node jester.xs.citrite.net > > Okay, you're all set! Check > /usr/share/foreman-installer/foreman_installer/answers.yaml for your > config. > > You can apply it in the future as root with: > echo include foreman_installer | puppet apply --modulepath > /usr/share/foreman-installer -v > > > Can someone tell me where the additional argument is coming from and how > I could correct the issue. I am running Debian Squeeze with clean > installation and was following the getting started instructions on the > foreman web site.–
Dominic Cleal
Red Hat Engineering
