After the upgrade from 1.20/1.21 to 1.22 all the hosts have the warning “System Purpose: Mismatched”:
the ansible callback, registration, licenses works fine and no other problems are present or errors in the production.log.
If I manually modify the field, eg as Standard, it start working:
There is a way to setup as Standard automatically? We’ve a huge number of server and editing each server manually will be “annoying”.
The System Purpose : Matched
1.22 / katello 1.12
foreman.noarch 1.22.0-1.el7
foreman-cli.noarch 1.22.0-1.el7
foreman-debug.noarch 1.22.0-1.el7
foreman-installer.noarch 1:1.22.0-1.el7
foreman-installer-katello.noarch 1:1.22.0-1.el7
foreman-postgresql.noarch 1.22.0-1.el7
foreman-proxy.noarch 1.22.0-1.el7
foreman-release.noarch 1.22.0-1.el7
foreman-release-scl.noarch 7-2.el7
foreman-selinux.noarch 1.22.0-1.el7
foreman-vmware.noarch 1.22.0-1.el7
katello-certs-tools.noarch 2.5.3-1.el7
katello-selinux.noarch 3.1.1-1.el7
katello.noarch 3.12.0-1.el7
katello-agent.noarch 3.5.0-2.el7
katello-client-bootstrap.noarch 1.7.2-2.el7
katello-common.noarch 3.12.0-1.el7
katello-debug.noarch 3.12.0-1.el7
katello-default-ca.noarch 1.0-1
katello-host-tools.noarch 3.5.0-2.el7
katello-host-tools-fact-plugin.noarch 3.5.0-2.el7
katello-repos.noarch 3.12.0-2.el7
katello-server-ca.noarch 1.0-1
katello-service.noarch 3.12.0-1.el7
pulp-katello.noarch 1.0.2-1.el7
No errors on production.log but after the upgrade I noticed a big increase of the used seconds into the runtime graph for every server:
