omenos
January 3, 2023, 7:11pm
1
After upgrading from Foreman 3.5.0-0.1.rc2 to 3.5.1 I’m seeing the following error check when trying to rebuild physical and virtual hosts:
The following errors may prevent a successful build:
Templates (1)
Failure parsing Kickstart default iPXE: undefined method `interpolate_vars’ for nil:NilClass.
Trying to continue regardless results in a “Request failed with status code 500”. Any ideas on what’s happening here?
omenos
January 3, 2023, 7:17pm
2
Package transaction of upgrade:
# sudo foremain-maintain packages update
$ sudo dnf history info 51
Transaction ID : 51
Begin time : Tue 03 Jan 2023 11:30:00 AM EST
Begin rpmdb : 1218:7d1502319f69924dd0fc1d901fd69d7588da5dcd
End time : Tue 03 Jan 2023 11:30:56 AM EST (56 seconds)
End rpmdb : 1218:24701dc477860808f20d2b34b912acb19ddd673e
User : Mike Rochefort
Return-Code : Success
Releasever : 8
Command Line : --disableplugin=foreman-protector update
Comment :
Packages Altered:
Upgrade foreman-3.5.1-1.el8.noarch @foreman
Upgraded foreman-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade foreman-cli-3.5.1-1.el8.noarch @foreman
Upgraded foreman-cli-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade foreman-debug-3.5.1-1.el8.noarch @foreman
Upgraded foreman-debug-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade foreman-dynflow-sidekiq-3.5.1-1.el8.noarch @foreman
Upgraded foreman-dynflow-sidekiq-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade foreman-ec2-3.5.1-1.el8.noarch @foreman
Upgraded foreman-ec2-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade foreman-installer-1:3.5.1-1.el8.noarch @foreman
Upgraded foreman-installer-1:3.5.0-0.1.rc2.el8.noarch @@System
Upgrade foreman-installer-katello-1:3.5.1-1.el8.noarch @foreman
Upgraded foreman-installer-katello-1:3.5.0-0.1.rc2.el8.noarch @@System
Upgrade foreman-postgresql-3.5.1-1.el8.noarch @foreman
Upgraded foreman-postgresql-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade foreman-proxy-3.5.1-1.el8.noarch @foreman
Upgraded foreman-proxy-3.5.0-0.1.rc2.el8.noarch @@System
Upgrade foreman-release-3.5.1-1.el8.noarch @foreman
Upgraded foreman-release-3.5.0-0.1.rc2.el8.noarch @@System
Upgrade foreman-selinux-3.5.1-1.el8.noarch @foreman
Upgraded foreman-selinux-3.5.0-0.1.rc2.el8.noarch @@System
Upgrade foreman-service-3.5.1-1.el8.noarch @foreman
Upgraded foreman-service-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade foreman-vmware-3.5.1-1.el8.noarch @foreman
Upgraded foreman-vmware-3.5.0-0.17.rc2.el8.noarch @@System
Upgrade rubygem-dynflow-1.6.8-1.el8.noarch @foreman
Upgraded rubygem-dynflow-1.6.7-1.fm3_4.el8.noarch @@System
Upgrade ansible-collection-theforeman-foreman-3.8.0-1.el8.noarch @foreman-plugins
Upgraded ansible-collection-theforeman-foreman-3.7.0-2.el8.noarch @@System
Scriptlet output:
1 warning: /etc/foreman-installer/scenarios.d/katello-answers.yaml created as /etc/foreman-installer/scenarios.d/katello-answers.yaml.rpmnew
2 ERROR: ld.so: object '/usr/libexec/coreutils/libstdbuf.so' from LD_PRELOAD cannot be preloaded (failed to map segment from shared object): ignored.
3 /sbin/restorecon: SELinux: Could not get canonical path for /etc/puppet/node.rb restorecon: No such file or directory.
4 ERROR: ld.so: object '/usr/libexec/coreutils/libstdbuf.so' from LD_PRELOAD cannot be preloaded (failed to map segment from shared object): ignored.
5 /sbin/restorecon: SELinux: Could not get canonical path for /etc/puppet/node.rb restorecon: No such file or directory.
omenos
January 3, 2023, 8:18pm
3
Problem resolved, this was due to the Operating System of the host changing from EL 8 to EL 8.7 and as such losing the designated installation media from the kickstart repositories.
i have the same error.
How do you have fixed it ?
Thank you
omenos
January 9, 2023, 2:26pm
5
As mentioned in the solution, the operating system value had changed for the hosts (e.g. EL 8.7 rather than EL8). This caused a disconnect for the host to find the appropriate installation media, so the resolution was twofold:
Disabling the automatic changing of host operating systems based on system facts (Settings > Facts).
Editing the hosts to use the correct operating system value.
