401 Unauthorized for db:seed and in candlepin (katello 2.4)
I updated my katello 2.3 system -> 2.4 last night and ran into issues. When
doing foreman-rake db:seed I got the following error.
foreman-rake db:seed --trace
** Invoke db:seed (first_time)
** Execute db:seed
** Invoke db:abort_if_pending_migrations (first_time)
** Execute environment
** Invoke db:load_config (first_time)
** Execute db:load_config
** Execute db:abort_if_pending_migrations
Seeding /usr/share/foreman/db/seeds.d/03-auth_sources.rb
Seeding /usr/share/foreman/db/seeds.d/03-permissions.rb
Seeding /usr/share/foreman/db/seeds.d/03-roles.rb
Seeding /usr/share/foreman/db/seeds.d/04-admin.rb
Seeding /usr/share/foreman/db/seeds.d/05-taxonomies.rb
Seeding /usr/share/foreman/db/seeds.d/06-architectures.rb
Seeding /usr/share/foreman/db/seeds.d/07-provisioning_templates.rb
Seeding /usr/share/foreman/db/seeds.d/08-partition_tables.rb
Seeding /usr/share/foreman/db/seeds.d/10-installation_media.rb
Seeding /usr/share/foreman/db/seeds.d/11-smart_proxy_features.rb
Seeding /usr/share/foreman/db/seeds.d/13-compute_profiles.rb
Seeding /usr/share/foreman/db/seeds.d/15-bookmarks.rb
Seeding /usr/share/foreman/db/seeds.d/16-mail_notifications.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.7.10/db/seeds.d/20-foreman_tasks_permissions.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_bootdisk-6.0.0/db/seeds.d/50-bootdisk_templates.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.7.10/db/seeds.d/60-dynflow_proxy_feature.rb
Seeding
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.7.10/db/seeds.d/61-foreman_tasks_bookmarks.rb
All seed files executed
rake aborted!
401 Unauthorized
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/abstract_response.rb:48:in
return!' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:92:inblock in get_response'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:in
call' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:228:inprocess_result'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbovirt-0.0.35/lib/restclient_ext/request.rb:50:in
block in transmit' /opt/rh/ruby193/root/usr/share/ruby/net/http.rb:746:instart'
/opt/theforeman/tfm/root/usr/share/gems/gems/rbovirt-0.0.35/lib/restclient_ext/request.rb:44:in
transmit' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:64:inexecute'
/opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/request.rb:33:in
execute' /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-1.6.7/lib/restclient/resource.rb:51:inget'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:91:in
get_response' /opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/base.rb:79:incall'
/opt/theforeman/tfm/root/usr/share/gems/gems/runcible-1.3.5/lib/runcible/resources/event_notifier.rb:71:in
list' /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/app/models/katello/glue/pulp/repo.rb:33:inensure_sync_notification'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/db/seeds.rb:31:in
<top (required)>' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:245:inload'
block in load' /opt/rh/ruby193/root/usr/share/gems/gems/activesupport-3.2.8/lib/active_support/dependencies.rb:236:inload_dependency'
load' /opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/engine.rb:520:inload_seed'
/opt/rh/ruby193/root/usr/share/gems/gems/railties-3.2.8/lib/rails/railtie/configurable.rb:30:in
method_missing&#39; /opt/theforeman/tfm/root/usr/share/gems/gems/katello-2.4.0/lib/katello/engine.rb:192:inblock (2 levels) in <class:Engine>'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:in call&#39; /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:205:inblock in execute'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:in each&#39; /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:200:inexecute'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:158:in block in invoke_with_call_chain&#39; /opt/rh/ruby193/root/usr/share/ruby/monitor.rb:211:inmon_synchronize'
/opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:151:in
invoke_with_call_chain&#39; /opt/rh/ruby193/root/usr/share/ruby/rake/task.rb:144:ininvoke'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:116:in invoke_task&#39; /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:inblock (2
levels) in top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:in each&#39; /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:94:inblock in
top_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:in
standard_exception_handling&#39; /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:88:intop_level'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:66:in block in run&#39; /opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:133:instandard_exception_handling'
/opt/rh/ruby193/root/usr/share/ruby/rake/application.rb:63:in run&#39; /opt/rh/ruby193/root/usr/bin/rake:32:in<main>'
Tasks: TOP => db:seed
When trying to manually sync a repo I see the following errors for
Actions::Katello::Repository::Sync RuntimeError: There was an issue with
the backend service pulp: Pulp message bus connection issue.
My product pages don't load at all and when I try to get info from hammer product info --id 29 I get Katello::Resources::Candlepin::Product: 401
Unauthorized {"displayMessage":"Invalid oauth unit
or secret","requestUuid":"64aba749-0384-409a-a32c-098a6f7064a1"} (GET
/candlepin/products/71)
Not really sure how I got in this state but could use some help. I'm in
#theforeman regularly if it's easier to help there. @jgarr
Thanks
Hello Justin,
Did you get any help with this Pulp message bus connection issue ?
I have the same problem, and cannot use pulp-related features
(products/repos/sync) in foreman/katello.
katello-service restart may help for a few minutes, but the problem comes
back very quickly.:
[app] [W] Pulp message bus connection issue. [app] [E] RuntimeError: There
was an issue with the backend service pulp: Pulp message bus connection
issue.
There seems to be a relevant Satellite bug that was fixed (
https://bugzilla.redhat.com/show_bug.cgi?id=1236096) in Satellite version
6.1.1, but we still see this error with the latest katello 2.4 / foreman
1.10.
··· > When trying to manually sync a repo I see the following errors for > Actions::Katello::Repository::Sync RuntimeError: There was an issue with > the backend service pulp: Pulp message bus connection issue. > > My product pages don't load at all and when I try to get info from `hammer > product info --id 29` I get Katello::Resources::Candlepin::Product: 401 > Unauthorized {"displayMessage":"Invalid oauth unit > or secret","requestUuid":"64aba749-0384-409a-a32c-098a6f7064a1"} (GET > /candlepin/products/71) > > Not really sure how I got in this state but could use some help. I'm in > #theforeman regularly if it's easier to help there. @jgarr > > Thanks > >
I don't actually remember with this specific issue. I don't have any
outstanding issues on my Satellite server and my Katello system got
reinstalled.
Sorry
– Justin
··· On Wed, Mar 30, 2016 at 11:51 AM, dcp wrote:
Hello Justin,
back very quickly.:
issue.
1236096 – Repository creation failed with pulp connection issue) in Satellite version
1.10.
My product pages don’t load at all and when I try to get info from
401 Unauthorized {“displayMessage”:“Invalid oauth unit
or secret”,“requestUuid”:“64aba749-0384-409a-a32c-098a6f7064a1”} (GET
Not really sure how I got in this state but could use some help. I’m in
#theforeman regularly if it’s easier to help there. @jgarr
Thanks
https://groups.google.com/d/topic/foreman-users/K6X4Eq-bOY4/unsubscribe.
Thanks for the reply, Justin…
Until now it seems we are the only unlucky users to experience this
intermittent issue that starts to become very frustrating… Thinking to
post a bug report on Issues - Katello - Foreman.
··· On Wednesday, March 30, 2016 at 3:54:37 PM UTC-4, Justin Garrison wrote: > > I don't actually remember with this specific issue. I don't have any > outstanding issues on my Satellite server and my Katello system got > reinstalled. > > Sorry > > > -- Justin > > On Wed, Mar 30, 2016 at 11:51 AM, dcp <dcp...@gmail.com > > wrote: > >> Hello Justin, >> >> Did you get any help with this Pulp message bus connection issue ? >> I have the same problem, and cannot use pulp-related features >> (products/repos/sync) in foreman/katello. >> katello-service restart may help for a few minutes, but the problem comes >> back very quickly.: >> >> [app] [W] Pulp message bus connection issue. [app] [E] RuntimeError: >> There was an issue with the backend service pulp: Pulp message bus >> connection issue. >> >> There seems to be a relevant Satellite bug that was fixed ( >> https://bugzilla.redhat.com/show_bug.cgi?id=1236096) in Satellite >> version 6.1.1, but we still see this error with the latest katello 2.4 / >> foreman 1.10. >> >> >> >>> When trying to manually sync a repo I see the following errors for >>> Actions::Katello::Repository::Sync RuntimeError: There was an issue with >>> the backend service pulp: Pulp message bus connection issue. >>> >>> My product pages don't load at all and when I try to get info from >>> `hammer product info --id 29` I get Katello::Resources::Candlepin::Product: >>> 401 Unauthorized {"displayMessage":"Invalid oauth unit >>> or secret","requestUuid":"64aba749-0384-409a-a32c-098a6f7064a1"} (GET >>> /candlepin/products/71) >>> >>> Not really sure how I got in this state but could use some help. I'm in >>> #theforeman regularly if it's easier to help there. @jgarr >>> >>> Thanks >>> >>> -- >> You received this message because you are subscribed to a topic in the >> Google Groups "Foreman users" group. >> To unsubscribe from this topic, visit >> https://groups.google.com/d/topic/foreman-users/K6X4Eq-bOY4/unsubscribe. >> To unsubscribe from this group and all its topics, send an email to >> foreman-user...@googlegroups.com . >> To post to this group, send email to forema...@googlegroups.com >> . >> Visit this group at https://groups.google.com/group/foreman-users. >> For more options, visit https://groups.google.com/d/optout. >> > >
If either of you can go ahead and file an issue with this, it would be
greatly appreciated and we can look into it more. Include any related error
messages in /var/log/messages
For good measure try running these commands in order:
systemctl restart qpidd
systemctl stop pulp_celerybeat.service pulp_resource_manager.service
pulp_workers.service
systemctl start pulp_celerybeat.service pulp_resource_manager.service
John Mitsch
Red Hat Engineering
(860)-967-7285
irc: jomitsch
I don’t actually remember with this specific issue. I don’t have any
reinstalled.
Sorry
– Justin
On Wed, Mar 30, 2016 at 11:51 AM, dcp dcp...@gmail.com wrote:
Hello Justin,
comes back very quickly.:
connection issue.
foreman 1.10.
Thanks
foreman-user...@googlegroups.com.
To post to this group, send email to forema...@googlegroups.com.
