A community member noted, with some detail[1], the dramatic slowness of apipie versus direct http requests. Any thoughts on this?
[1] Bug #6075: apipie significantly slower than naive API calls - Hammer CLI - Foreman
@thomasmckay
“The leader must aim high, see big, judge widely, thus setting himself apart form the ordinary people who debate in narrow confines.” ~ Charles De Gaulle
“Leadership is about making others better as a result of your presence and making sure that impact lasts in your absence.” ~ Harvard Business School
The difference is caused by apipie-bindings, as all the three client
implementations call the same (apipie documented) API on the server.
There is a couple of extra things that the binding does, e.g. apidoc
cache checking, correct route evaluation based on parameters.
I'll check if the performance of apipie-bindings could be improved or
fixed be more suitable configuration.
Martin
> [1] http://projects.theforeman.org/issues/
