Is there a way to inform foreman a build has failed, say doing some
validations in kickstart and abort the installation?
No, there's no way to do this - a host can only be in build-mode or not,
there is no failed-build status. I think it would require moving the build
orchestration to something more detailed to support it, but you're welcome
to log a feature request on the bug tracker
ยทยทยท
On 3 February 2016 at 17:06, ghidu wrote:Is there a way to inform foreman a build has failed, say doing some
