Running foreman 1.1 and noticed when i create new host and select the
appropriate network type, when i login to vsphere it shows up as a blank
network type and i need to select the dropdown and change it.
When i view the network in foreman it shows up as "bootp (VLan 200)"
Yet, in VSphere it appears it should be "bootp (VLan 200) (Blade-vDs)" - I
see its set to "Bootp (Vlan 200)" in vsphere but the network dropdown is
blank like nothing is associated until i select the one with the
(Blade-vDs) suffix.
I updated FOG and RBVMOMI (net-scp & net-ssh as well) and fixed
dependencies in the gemlock and i can now create new hosts just fine, it
doesn't have the same bug.
Any chance we will get a new 1.11 build or something soon to incorporate
some of the newer dependencies?
-byron
> I see its set to "Bootp (Vlan 200)" in vsphere but the network dropdown is
> (Blade-vDs) suffix.
this is pretty simple to fix, e.g:
edit bundler.d/fog.rb
bump 1.09 to 1.10
and run
bundle
as the foreman user.
in the meanwhile its probably best to update the wiki to reflect it.
Ohad
On Mon, Mar 25, 2013 at 9:21 PM, Byron Miller wrote:
-byron
When i view the network in foreman it shows up as “bootp (VLan 200)”
Yet, in VSphere it appears it should be “bootp (VLan 200) (Blade-vDs)” -
I see its set to “Bootp (Vlan 200)” in vsphere but the network dropdown is
(Blade-vDs) suffix.
"Foreman users" group.
Visit this group at http://groups.google.com/group/foreman-users?hl=en.
