Now that foreman 1.22.0 has been released, I could really use some advice on how to upgrade.
I lifted a prior comment from a posting in another thread called Getting Started from back in March …
I’ve been following a few other threads regarding upgrades …
Any known compatibility issues?
I just got this stuff working.
I’m afraid to break it, and having to start over.
Not even sure I would know where to begin again?
So, my question now is: What do I do first? Katello? Foreman 1.21 then 1.22?
If using Katello wait for its release and then follow the instructions in Foreman :: Plugin Manuals. If you want to know more about the update including warnings read both release notes (Foreman and Katello).
I only had updates fail when I had manually installed plugins and release quality was always good enough so I had no need to rollback.
With plugins:
foreman_openscap 0.11.5
datadog_agent 2.6.0
jasmin
lucee
nodejs
(among others … )
Now that katello 3.12 and foreman 1.22.0 are released,
can I upgrade directly from foreman 1.20.2 to 1.22.0, or do I need to upgrade to 1.21.3 first?
How about the intermediary releases in between?
