I have installed foreman and ansible on same host and enable call backs i
can see some options to use ansible on foreman.
but when i execute a playbook i get this error
ERROR:-
[WARNING]: Failure using method (v2_playbook_on_stats) in callback plugin
(</usr/share/ansible/plugins/callback/foreman_callback.CallbackModule
object at 0x3047ed0>): [Errno 13] Permission denied
Pemrmission denied sounds like the user running your ansible process
cannot read the certificate files:
I had this problem as well and Daniel's right. I fixed it back then by
changing the the access rights of the certs.
> *ERROR:-*
> ( object at 0x3047ed0>): [Errno 13] Permission denied
> *ANSIBLE*:-
> ansible 2.3.0
> config file = /etc/ansible/ansible.cfg
> configured module search path = Default w/o overrides
> *FOREMAN_CALLBACK.PY:-*
> FOREMAN_URL = os.getenv('FOREMAN_URL', "https://10.97.13.216")
> # Substitute by a real SSL certificate and key if your Foreman uses HTTPS
> FOREMAN_SSL_CERT = (os.getenv('FOREMAN_SSL_CERT',
> "/var/lib/puppet/ssl/certs/ip-10-97-13-216.ec2.internal.pem"),
> os.getenv('FOREMAN_SSL_KEY',
> "/var/lib/puppet/ssl/private_keys/ip-10-97-13-216.ec2.internal.pem"))
> FOREMAN_SSL_VERIFY = os.getenv('FOREMAN_SSL_VERIFY', "0")
> the url is the url where i access foreman
> The playbook is trying to conect to local host and execute
> - hosts: 10.97.13.216
> gather_facts: true
> tasks:
> - name: testing playbook
> yum: name=ntp state=latest
