When I install the Ansible plugin using the foreman-installer and configure the callback module in the Ansible.conf file with the certificates the are listed on the UI Administer >> Settings >> Authentication and run a playbook the nodes does not populate on the Hosts. I was able to get this working without katello installed, I have tried reinstalling centos 7.
When I run the playbook the node should populate onto the hosts UI.
Foreman 2.0.1
Centos 7.8
