Problem: When I launch a playbook : I get the callback report but the, display of the report gets the json format which is not user friendly to read. And also shows the origin as N/A.
I heard that on Foreman 1.18 ansible reports had an improvment on showing json view more easier to read.
I have Foreman 1.24 installed but not working as I thought…
Is there any additional installations that I have to do?
I have exactly the same problem. Running Playbooks or Roles directly from Foreman, leads to origin N/A and hard readable json report format.
If I’m triggering a playbook from command line everything works (Ansible logo as origin and yaml formatted report).
Foreman and Proxy Versions
Foreman: 2.3.2
Foreman proxy : 2.3.2
