Problem: Installer complains at the Apache stage since Nginx is running and bound on 443
uname and installer log attachedProcessing: log.log…
new users can’t upload attachments
ok, shoving it here:
x@y:/tmp$ uname -a
Linux y 4.19.0-17-amd64 #1 SMP Debian 4.19.194-3 (2021-07-18) x86_64 GNU/Linux
x@y:/tmp$ sudo foreman-installer
2021-09-18 10:19:04 [NOTICE] [root] Loading installer configuration. This will take some time.
2021-09-18 10:19:07 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.
2021-09-18 10:19:07 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.
2021-09-18 10:19:08 [NOTICE] [configure] Starting system configuration.
2021-09-18 10:19:13 [NOTICE] [configure] 250 configuration steps out of 1331 steps complete.
2021-09-18 10:19:14 [NOTICE] [configure] 500 configuration steps out of 1333 steps complete.
2021-09-18 10:19:14 [NOTICE] [configure] 750 configuration steps out of 1440 steps complete.
2021-09-18 10:19:14 [NOTICE] [configure] 1000 configuration steps out of 1441 steps complete.
2021-09-18 10:19:23 [ERROR ] [configure] Systemd start for apache2 failed!
2021-09-18 10:19:23 [ERROR ] [configure] journalctl log for apache2:
2021-09-18 10:19:23 [ERROR ] [configure] -- Logs begin at Sat 2021-09-18 09:48:24 PDT, end at Sat 2021-09-18 10:19:23 PDT. --
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y systemd[1]: Starting The Apache HTTP Server...
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y apachectl[12762]: (98)Address already in use: AH00072: make_sock: could not bind to address [::]:443
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y apachectl[12762]: (98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:443
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y apachectl[12762]: no listening sockets available, shutting down
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y apachectl[12762]: AH00015: Unable to open logs
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y apachectl[12762]: Action 'start' failed.
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y apachectl[12762]: The Apache error log may have more information.
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y systemd[1]: apache2.service: Failed with result 'exit-code'.
2021-09-18 10:19:23 [ERROR ] [configure] Sep 18 10:19:23 y systemd[1]: Failed to start The Apache HTTP Server.
2021-09-18 10:19:23 [ERROR ] [configure] /Stage[main]/Apache::Service/Service[httpd]/ensure: change from 'stopped' to 'running' failed: Systemd start for apache2 failed!
2021-09-18 10:19:23 [NOTICE] [configure] 1250 configuration steps out of 1441 steps complete.
2021-09-18 10:19:24 [NOTICE] [configure] System configuration has finished.
The full log is at /var/log/foreman-installer/foreman.log
x@y:/tmp$
