dodo
February 3, 2022, 11:37am
1
I’ve added Remi Repo Modular EL8 and enabled remi-php7.4 Module Stream
But Katello shows applicable Packages php8.0/php8.1
These Module Streams are not enabled
If i do a
dnf update on the system, DNF correctly recognize there are no updates available for remi-php7.4
Dont show diabled AppStream Packages as applicable
Katello 4.22
Foreman 3.0.1
Almalinux 8.5
I’ve upgraded Katello from 4.1 to 4.2
Problem already existed in latest 4.1
dodo
February 8, 2022, 9:45am
2
Hello again,
this Problem gets super annoying.
I even created a filter and excluded all remi-php8 and remi-php8.1 module streams
these module streaems does not show up when i do
dnf module list
on an client
but still php8.x shows as applicable
i even diabled remi repo all together,
dnf uploadprofile --force-upload
re added remi repo
and its still showing php8.x as applicable
Hi @dodo
thanks for reporting this! We’re going to see if we can reproduce the issue. Is that repo publicly available somewhere?
dodo
February 9, 2022, 7:24am
4
thank you,
please let me know if i can help you to figure this out.
Remi Repo is a known PHP Repo
https://rpms.remirepo.net/
affected Modular Repo
https://rpms.remirepo.net/enterprise/8/modular/x86_64/
dodo
February 22, 2022, 9:13am
5
@jeremylenz
just want to check in and see if you found something?
Do i need to provide more information?
Thank you
Hi @dodo
We just haven’t gotten a developer to look at it yet. It’s on our to-do list.
I created Bug #34487: Katello shows RPMs from non-enabled module streams as applicable - Katello - Foreman
so the issue can be tracked.
lfu
March 17, 2022, 8:24pm
7
@dodo I can’t re-produce the issue with Katello 4.2 and your provided Remi repo.
Does the issue still exist in your environment?
Thanks.
dodo
March 18, 2022, 10:24am
8
Thank you for looking into this.
sadly yes, still same issue
Any tips for troubleshooting this further?
Thank you !
P.S
Just to make sure
you did install some php74 packages?
like
php-common-7.4.28-1.el8.remi.x86_64
php-gd-7.4.28-1.el8.remi.x86_64
php-mbstring-7.4.28-1.el8.remi.x86_64
php-pecl-zip-1.20.0-1.el8.remi.7.4.x86_64
php-json-7.4.28-1.el8.remi.x86_64
php-pdo-7.4.28-1.el8.remi.x86_64
php-gmp-7.4.28-1.el8.remi.x86_64
php-xml-7.4.28-1.el8.remi.x86_64
php-imap-7.4.28-1.el8.remi.x86_64
php-opcache-7.4.28-1.el8.remi.x86_64
php-mysqlnd-7.4.28-1.el8.remi.x86_64
php-fpm-7.4.28-1.el8.remi.x86_64
php-intl-7.4.28-1.el8.remi.x86_64
lfu
March 18, 2022, 1:36pm
9
The php packages installed locally:
[vagrant@rhel85 ~]$ rpm -qa |grep php
php-cli-7.4.28-1.el8.remi.x86_64
oniguruma5php-6.9.7.1-1.el8.remi.x86_64
Could you try disable then re-enable your php module stream?
If it still doesn’t work, could you try with a refresh new foreman/katello environment?
Please keep us updated.
Thank you.
lfu
March 30, 2022, 12:03pm
10
@dodo Any update? Were you able to resolve it?
dodo
April 6, 2022, 10:52am
11
hi
sorry for tha late reply
i was on vacation
could test ist yet, so sorry
Thanks for all your help
ich try to test ASAP
Thank you
dodo
April 18, 2022, 11:47am
12
heya,
i just installed katello 4.4.0.2
added remi repo safe + modular (same as at work)
installed some packages
everything is fine like you said…
it seems to some problem with calculating applicable packages…maybe something went wrong with some updates ( this installation is since 3.8)
can you please guide me to do some troubleshooting?
maybe just some bad DB entrys?
thank you
greetings
dodo
dodo
April 18, 2022, 11:53am
13
At Work i’m on same version
Issue still persist
I also tried to unsubscribe the Host and re added it
did some subscripiption-manager refresh --force tries
still same issue
If needed i can provide full detailed troubleshooting steps for subscription-manager
it’s still happening when i subscribe a new fresh host …
dodo
April 18, 2022, 11:56am
14
maybe i will try and recreate the whole PHP “Product” disable the old and enable the new repo’s
maybe it’s worth a try
i will report back
dodo
April 27, 2022, 6:26am
15
Problem is solved
I recreated the Remi Modular Repositories and now everything show up as expected
Thank you
