Applied errata report failing with error undefined method `split' for nil:NilClass
getting below error message and no report is generated,
undefined method `split’ for nil:NilClass (NoMethodError)
report with all applied erratas for all servers (currently ~35 registered servers only)
foreman version 1.24.3
katello version 3.14.1
Linux redhat 7.6
2020-09-02T22:15:32 [E|bac|42aa0655] undefined method `split' for nil:NilClass (NoMethodError)
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/katello/concerns/base_template_scope_extensions.rb:148:in `parse_errata'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/katello/concerns/base_template_scope_extensions.rb:99:in `block (2 levels) in load_errata_applications'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/relation/delegation.rb:41:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/katello/concerns/base_template_scope_extensions.rb:98:in `block in load_errata_applications'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/relation/batches/batch_enumerator.rb:64:in `block in each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/relation/batches.rb:238:in `block in in_batches'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/relation/batches.rb:222:in `loop'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/relation/batches.rb:222:in `in_batches'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/relation/batches/batch_enumerator.rb:64:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/katello/concerns/base_template_scope_extensions.rb:93:in `load_errata_applications'
Applied Errata:3:in `get_binding'
/opt/rh/rh-ruby25/root/usr/share/ruby/erb.rb:876:in `eval'
/opt/rh/rh-ruby25/root/usr/share/ruby/erb.rb:876:in `result'
/usr/share/foreman/lib/foreman/renderer/unsafe_mode_renderer.rb:7:in `render'
/usr/share/foreman/lib/foreman/renderer/base_renderer.rb:16:in `render'
/usr/share/foreman/lib/foreman/renderer.rb:46:in `render'
/usr/share/foreman/app/models/template.rb:174:in `render'
/usr/share/foreman/app/models/report_composer.rb:241:in `render'
/usr/share/foreman/app/jobs/template_render_job.rb:10:in `block in perform'
/usr/share/foreman/app/models/concerns/foreman/thread_session.rb:108:in `as'
/usr/share/foreman/app/jobs/template_render_job.rb:7:in `perform'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/execution.rb:39:in `block in perform_now'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/i18n-1.4.0/lib/i18n.rb:284:in `with_locale'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/translation.rb:9:in `block (2 levels) in <module:Translation>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:118:in `instance_exec'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/logging.rb:26:in `block (4 levels) in <module:Logging>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/logging.rb:25:in `block (3 levels) in <module:Logging>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/logging.rb:48:in `tag_logger'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/logging.rb:22:in `block (2 levels) in <module:Logging>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/execution.rb:35:in `perform_now'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/execution.rb:24:in `block in execute'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/railtie.rb:28:in `block (4 levels) in <class:Railtie>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/execution_wrapper.rb:87:in `wrap'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/reloader.rb:73:in `block in wrap'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/reloader.rb:72:in `wrap'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/railtie.rb:27:in `block (3 levels) in <class:Railtie>'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activejob-5.2.1/lib/active_job/execution.rb:22:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/active_job/queue_adapter.rb:47:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:563:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:27:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:19:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action/progress.rb:31:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action/progress.rb:17:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/stack.rb:23:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/keep_locale.rb:11:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/keep_locale.rb:22:in `with_locale'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-3.14.1/app/lib/actions/middleware/keep_locale.rb:11:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_request_id.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_request_id.rb:49:in `restore_current_request_id'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_request_id.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_timezone.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_timezone.rb:44:in `restore_curent_timezone'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_timezone.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_user.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_user.rb:44:in `restore_curent_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_user.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in `restore_current_taxonomies'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-0.17.5/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware.rb:32:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/middleware/world.rb:31:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:562:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:561:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:561:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:475:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:475:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:475:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:556:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/action.rb:285:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract.rb:167:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/director.rb:68:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/worker.rb:15:in `block in on_message'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors.rb:12:in `run_user_code'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/worker.rb:14:in `on_message'
[ concurrent-ruby ]
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/pool.rb:99:in `distribute_jobs'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/pool.rb:52:in `schedule_work'
[ concurrent-ruby ]
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/core.rb:48:in `block in feed_pool'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/core.rb:46:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel/core.rb:46:in `feed_pool'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/abstract/core.rb:123:in `handle_work'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/abstract/core.rb:26:in `handle_execution'
[ concurrent-ruby ]
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/abstract/core.rb:113:in `on_message'
[ concurrent-ruby ]
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/executors/parallel.rb:24:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/dispatcher/executor_dispatcher.rb:30:in `perform_execution'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/dispatcher/executor_dispatcher.rb:12:in `block in handle_request'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:74:in `block in assigns'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:73:in `tap'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matchers/abstract.rb:73:in `assigns'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:56:in `match_value'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:36:in `block in match?'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:35:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:35:in `match?'
/opt/theforeman/tfm/root/usr/share/gems/gems/algebrick-0.7.3/lib/algebrick/matching.rb:23:in `match'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/dispatcher/executor_dispatcher.rb:11:in `handle_request'
[ concurrent-ruby ]
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/abstract.rb:39:in `block in receive'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/abstract.rb:33:in `receive'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/database.rb:92:in `handle_envelope'
[ concurrent-ruby ]
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/database.rb:114:in `block in receive_envelopes'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/database.rb:113:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/database.rb:113:in `receive_envelopes'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/database.rb:83:in `check_inbox'
[ concurrent-ruby ]
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/database.rb:27:in `block (2 levels) in start'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:432:in `wait_for_notify'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:432:in `block (4 levels) in listen'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:430:in `loop'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:430:in `block (3 levels) in listen'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:429:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:429:in `block (2 levels) in listen'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/connection_pool/threaded.rb:91:in `hold'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/database/connecting.rb:269:in `synchronize'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:412:in `block in listen'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:478:in `check_database_errors'
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-5.7.1/lib/sequel/adapters/postgres.rb:411:in `listen'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.4.2/lib/dynflow/connectors/database.rb:25:in `block in start'
[ concurrent-ruby ]
2020-09-02T22:15:33 [I|app|62c3e444] Started GET "/api/v2/report_templates/113-Applied%20Errata/report_data/e7f630e4-9e6f-43a7-8ed6-ca5eee22d6b9" for ::1 at 2020-09-02 22:15:33 +0300
2020-09-02T22:15:33 [I|app|62c3e444] Processing by Api::V2::ReportTemplatesController#report_data as JSON
2020-09-02T22:15:33 [I|app|62c3e444]   Parameters: {"apiv"=>"v2", "id"=>"113-Applied Errata", "job_id"=>"e7f630e4-9e6f-43a7-8ed6-ca5eee22d6b9"}
2020-09-02T22:15:33 [I|app|62c3e444] Completed 422 Unprocessable Entity in 24ms (Views: 1.7ms | ActiveRecord: 6.0ms)
did you use REX to apply errata or katello agent?
i used katello agent, installed REX plugin but never used it
