Thanks for your help its much appreciated.
All has been syncing fine, however for nor real reason. Iâm now getting error and failed sync
" PulpCodedException: Checksum type âsha256â is not available for all units in the repository. Make sure those units have been downloaded "
I dont have an srpmâs which can cause this seems to widespread through all content views.
Things that have changed
installed ansible plugin
applied updates of 7.9 centos to Foreman and proxyâs
I edited /etc/systemd/system/pulpcore-content.service increased the workers to 2*+1CPU, I never could get that timeout syntax to work. Pulp would never srtart
ExecStart=/usr/libexec/pulpcore/gunicorn pulpcore.content:server
âworker-class âaiohttp.GunicornWebWorkerâ
-w 25
âaccess-logfile -
ExecReload=/bin/kill -s HUP $MAINPID
SyslogIdentifier=pulpcore-content
I have removed product packages of repo, resycâd, published, republished contentviews.
full sync with removed lifecycles - which works but didnt really seem to clear out the DB the way I expected.
Now just trying to sync using just 1 content view - fails
removed pulp worker cache as flesystem went to 100%
restart pulp workers, reboot proxy and foreman
removed orphans
Ive been round this in a loop a few times now
Any sugggestions ?
Hi @sinewave,
Are you still on Katello 3.18? Do you have the latest pulp-rpm 3.11 version?
I found a bugzilla talking about what I think is the same issue: 1958415 â On_demand capsule sync (pulp3 to pulp2) for non-sha256 repos fails with a checksum type issue
The problem seems to have been partially fixed in pulp-rpm 3.11 but it seems some of it had to be fixed in later versions: https://bugzilla.redhat.com/show_bug.cgi?id=1958415#c12
A workaround is mentioned there if necessary.
There wonât be more releases of pulp-rpm 3.11, so if the issue isnât solved by the patch mentioned in that bugzilla, Iâd highly recommend upgrading.
Hi, thanks for replyin. Iâve out the proxy on immediatesync.
Yes Iâm still on same version until I an get a test system set up to run tthough the upgrade. Hopefully can get that upgrade planned out soon.
IIt is taking a very long time to sync. its not happy with something
Actions::Pulp::Consumer::SyncCapsule
State:suspended
Input:
{âcapsule_idâ=>6,
ârepo_pulp_idâ=>
â3-Centos7_content-test1-0a63d369-6561-4dce-8f2f-4b9a621af369â,
ârepository_idâ=>1528,
âsync_optionsâ=>{âremove_missingâ=>true, âforce_fullâ=>true},
âremote_userâ=>âadminâ,
âremote_cp_userâ=>âadminâ,
âcurrent_request_idâ=>nil,
âcurrent_timezoneâ=>âEurope/Londonâ,
âcurrent_user_idâ=>4,
âcurrent_organization_idâ=>3,
âcurrent_location_idâ=>2}
Output:
{âsmart_proxy_history_idâ=>30442,
âpulp_tasksâ=>
[{âexceptionâ=>nil,
âtask_typeâ=>âpulp.server.managers.repo.sync.syncâ,
â_hrefâ=>"/pulp/api/v2/tasks/adbacfc4-276c-4691-9d88-df3dbd7ae8e8/",
âtask_idâ=>âadbacfc4-276c-4691-9d88-df3dbd7ae8e8â,
âtagsâ=>
[âpulp:repository:3-Centos7_content-test1-0a63d369-6561-4dce-8f2f-4b9a621af369â,
âpulp:action:syncâ],
âfinish_timeâ=>nil,
â_nsâ=>âtask_statusâ,
âstart_timeâ=>â2022-04-06T08:47:50Zâ,
âtracebackâ=>nil,
âspawned_tasksâ=>,
âprogress_reportâ=>
{âyum_importerâ=>
{âcontentâ=>
{âitems_totalâ=>10573,
âstateâ=>âIN_PROGRESSâ,
âerror_detailsâ=>
[{âurlâ=>
"https://foreman.inf.itsystems.global/pulp/repos/IT_Systems_Global/test1/Centos7_content/custom/CentOS7_Base/Centos7_extras_x86_64/Packages/m/mvapich2-2.2-2.2-4.el7.i686.rpm",
** âerrorsâ=>[âProxy Errorâ]}],**
âdetailsâ=>
{ârpm_totalâ=>10573,
ârpm_doneâ=>9838,
âdrpm_totalâ=>0,
âdrpm_doneâ=>0},
âsize_totalâ=>10542941600,
âsize_leftâ=>550327256,
âitems_leftâ=>735},
âcompsâ=>{âstateâ=>âNOT_STARTEDâ},
âpurge_duplicatesâ=>{âstateâ=>âNOT_STARTEDâ},
âdistributionâ=>
{âitems_totalâ=>0,
âstateâ=>âNOT_STARTEDâ,
âerror_detailsâ=>,
âitems_leftâ=>0},
âmodulesâ=>{âstateâ=>âNOT_STARTEDâ},
âerrataâ=>{âstateâ=>âNOT_STARTEDâ},
âmetadataâ=>{âstateâ=>âFINISHEDâ}}},
âqueueâ=>
âreserved_resource_worker-9@foreman-proxy.inf.itsystems.global.dq2â,
âstateâ=>ârunningâ,
âworker_nameâ=>
âreserved_resource_worker-9@foreman-proxy.inf.itsystems.globalâ,
âresultâ=>nil,
âerrorâ=>nil,
â_idâ=>{"$oid"=>â624d53b61a288934535d83c9â},
âidâ=>â624d53b61a288934535d83c9â}],
âpoll_attemptsâ=>{âtotalâ=>1227, âfailedâ=>0}}
Only one proxy server seems to have a problem now. I removed all content and did a sync which worked. Then added small amount of test content and that worked.
However sync job just runs for days looks like it just times out then moves on. Any idea @iballou ?
{âcapsule_idâ=>6,
ârepo_pulp_idâ=>
â3-Oracle7_Foreman23_katello_client_UEK3-Spacewalk-cca1332e-f426-40ee-b917-581a287f0740â,
ârepository_idâ=>1059,
âsync_optionsâ=>{âremove_missingâ=>true},
Output:
{âsmart_proxy_history_idâ=>31451,
âpulp_tasksâ=>
[{âexceptionâ=>nil,
â_hrefâ=>"/pulp/api/v2/tasks/2a528de9-0c25-476c-b7d6-12e0fe3d0858/",
âtask_idâ=>â2a528de9-0c25-476c-b7d6-12e0fe3d0858â,
âtagsâ=>
[âpulp:repository:3-Oracle7_Foreman23_katello_client_UEK3-Spacewalk-cca1332e-f426-40ee-b917-581a287f0740â,
âfinish_timeâ=>nil,
âstart_timeâ=>â2022-04-19T15:40:56Zâ,
âtracebackâ=>nil,
âspawned_tasksâ=>,
âprogress_reportâ=>
{âyum_importerâ=>
{âcontentâ=>
{âitems_totalâ=>821,
"error_details"=>
** [{âurlâ=>**
** âhttps://gbh-foremanl/pulp/repos/IT_Systems_Global/Spacewalk/Oracle7_Foreman23_katello_client_UEK3/custom/Oracle_Linux_7_UEK_3/Oracle_Linux_7_UEK_3/Packages/k/kernel-uek-firmware-3.8.13-118.15.3.el7uek.noarch.rpmâ,**
âdetailsâ=>
{ârpm_totalâ=>821,
ârpm_doneâ=>803,
âdrpm_totalâ=>0,
âdrpm_doneâ=>0},
âsize_totalâ=>11656402624,
âsize_leftâ=>276469776,
âitems_leftâ=>18},
âdistributionâ=>
{âitems_totalâ=>0,
âerror_detailsâ=>,
âitems_leftâ=>0},
âqueueâ=>
âreserved_resource_worker-9@foreman-proxy.dq2â,
âstateâ=>ârunningâ,
âworker_nameâ=>
âreserved_resource_worker-9@foreman-proxyâ,
âresultâ=>nil,
âerrorâ=>nil,
â_idâ=>{"$oid"=>â625ea7ec5f4417acf07a6f58â},
âidâ=>â625ea7ec5f4417acf07a6f58â}],
âpoll_attemptsâ=>{âtotalâ=>4536, âfailedâ=>0}}
Hi @sinewave,
Are there any proxies between your smart proxy mirror (id 6) and your foreman instance? Just trying to download that kernel-uek-firmware-3.8.13-118.15.3.el7uek.noarch.rpm
package would be a good first test.
Iâll ask the Pulp team if they remember any issues relating to Pulp 2 â Pulp 3 syncs and Proxy Error
Another place to look for info would be the apache logs. The Proxy Error is likely indicating that thereâs a timeout going on somewhere
my wget from proxy to the foreman server worked fine with no problems
ârpm_totalâ=>821,
ârpm_doneâ=>803,
This seems to me that pulp is succeeding with some of the packages and then failing for a few. Do you see any relevant logs at /var/log/messages on the proxy when syncing stops?
there are some wrrors in the apache log on the proxy.
The sync has bee running for days and still running probably due to these continuous timeouts.
foreman-proxy goferd: [WARNING][pulp.agent.47cf9c70-116e-4009-bc88-87cbe18157b0] gofer.messaging.adapter.proton.reliability:54 - Connection amqps://foreman.global:5647 disconnected: Condition(âamqp:resource-limit-exceededâ, âlocal-idle-timeout expiredâ)
One other funny is that even with 0 content and job completes successfully. On the smart proxy page in foreman where you start synchronisation it never says 100% on the green bar. all other proxyâs are fine.
What are the foreman server and proxy version you are on?
Is the dynflow task for the capsule sync task complete or does it say pending/paused? Some screenshots of the task and expanded sub-task if itâs in paused/suspended states will be helpful.
Also a complete sync on the proxy and monitoring the /var/log/messages in case itâs stuck for any errors.
Hi, thanks for your help on this.
Here are version list , apache error logs, message log and dynflow console for actions of success, pulp checking and pending.
Iâm running Foreman 2.3.5
⢠foreman-2.3.5-1.el7.noarch
⢠foreman-cli-2.3.5-1.el7.noarch
⢠foreman-debug-2.3.5-1.el7.noarch
⢠foreman-dynflow-sidekiq-2.3.5-1.el7.noarch
⢠foreman-installer-2.3.5-1.el7.noarch
⢠foreman-installer-katello-2.3.5-1.el7.noarch
⢠foreman-postgresql-2.3.5-1.el7.noarch
⢠foreman-proxy-2.3.5-1.el7.noarch
⢠foreman-release-2.3.5-1.el7.noarch
⢠foreman-selinux-2.3.5-1.el7.noarch
⢠foreman-service-2.3.5-1.el7.noarch
Katello 3.14
Pulp 3 on foreman
Pulp2 on proxy
Proxy /var/log/messages a few examples:
Apr 22 11:23:29 foreman-proxy pulp: urllib3.connectionpool:INFO: Starting new HTTPS connection (1): foreman.inf.itsystems.global
Apr 22 11:23:29 foreman-proxy goferd: [INFO][pulp.agent.47cf9c70-116e-4009-bc88-87cbe18157b0] proton:1054 - Connected to foreman.inf.itsystems.global
Apr 22 11:23:29 foreman-proxy goferd: [INFO][pulp.agent.47cf9c70-116e-4009-bc88-87cbe18157b0] gofer.messaging.adapter.proton.connection:92 - opened: proton+amqps://foreman.inf.itsystems.global:5647
Apr 22 11:23:29 foreman-proxy goferd: [INFO][pulp.agent.47cf9c70-116e-4009-bc88-87cbe18157b0] gofer.messaging.adapter.connect:30 - connected: proton+amqps://foreman.inf.itsystems.global:5647
Apr 22 11:23:32 foreman-proxy pulp: nectar.downloaders.threaded:INFO: Download succeeded: https://foreman.inf.itsystems.global/pulp/repos/IT_Systems_Global/Production/Centos6_foreman23_Katello_client/custom/CentOS6_Base/CentOS6_epel_x86_64/Packages/u/unison227-2.27.57-13.el6.x86_64.rpm.
Apr 22 11:23:32 foreman-proxy pulp: urllib3.connectionpool:INFO: Starting new HTTPS connection (1): foreman.inf.itsystems.global
Apr 22 11:23:32 foreman-proxy pulp: nectar.downloaders.threaded:INFO: Download succeeded: https://foreman.inf.itsystems.global/pulp/repos/IT_Systems_Global/Non-Production/Oracle6_foreman23_Katello_client/custom/CentOS6_Base/CentOS6_epel_x86_64/Packages/p/perl-Devel-Hexdump-0.02-1.el6.x86_64.rpm.
Apr 22 11:23:33 foreman-proxy pulp: nectar.downloaders.threaded:INFO: Download succeeded: https://foreman.inf.itsystems.global/pulp/repos/IT_Systems_Global/Production/Centos6_foreman23_Katello_client/custom/CentOS6_Base/CentOS6_epel_x86_64/Packages/s/snmpcheck-1.8-4.el6.noarch.rpm.
Apr 22 11:23:33 foreman-proxy pulp: urllib3.connectionpool:INFO: Starting new HTTPS connection (1): foreman.inf.itsystems.global
Apr 22 11:23:33 foreman-proxy pulp: nectar.downloaders.threaded:INFO: Download succeeded: https://foreman.inf.itsystems.global/pulp/repos/IT_Systems_Global/Non-Production/Oracle6_Content/custom/Oracle_Linux_6_Base/Oracle_Linux_6_base_x86_64/Packages/j/java-1.8.0-openjdk-headless-debug-1.8.0.262.b10-0.el6_10.x86_64.rpm.
Apr 22 11:23:37 foreman-proxy pulp: nectar.downloaders.threaded:INFO: Download succeeded: https://foreman.inf.itsystems.global/pulp/repos/IT_Systems_Global/Non-Production/Oracle6_Content/custom/Oracle_Linux_6_Base/Oracle_Linux_6_base_x86_64/Packages/k/kdemultimedia-devel-4.3.4-3.el6.i686.rpm.
Apr 22 11:23:37 foreman-proxy pulp: urllib3.connectionpool:INFO: Starting new HTTPS connection (1): foreman.inf.itsystems.global
Apr 22 11:23:37 foreman-proxy qdrouterd: SERVER (info) [C25825] Accepted connection to :5647 from 100.8.127:60840
Apr 22 11:23:37 foreman-proxy qdrouterd: SERVER (info) [C25825] Connection from â a ClientIPâ:60840 (to :5647) failed: amqp:connection:framing-error No protocol header found (connection aborted)
Apr 22 11:23:37 foreman-proxy qdrouterd: SERVER (info) [C25826] Accepted connection to :5647 from 100.:34340
Apr 22 11:23:37 foreman-proxy qdrouterd: SERVER (info) [C25826] Connection from âa Clientâ:34340 (to :5647) failed: amqp:connection:framing-error No protocol header found (connection aborted)
Apr 22 11:23:37 foreman-proxy pulp: nectar.downloaders.threaded:INFO: Download succeeded: https://foreman.inf.itsystems.global/pulp/repos/IT_Systems_Global/Non-Production/Oracle6_foreman23_Katello_client/custom/CentOS6_Base/CentOS6_epel_x86_64/Packages/p/python-remoteobjects-1.2.1-1.el6.noarch.rpm.
Apache error logs
pulp-https_error_ssl.log
[Wed Apr 20 12:13:34.569342 2022] [ssl:warn] [pid 585] [client âForemanâ:53468] AH02227: Failed to set r->user to âSSL_CLIENT_S_DN_CNâ
error_log
[Tue Apr 19 11:36:12.053596 2022] [so:warn] [pid 1290] AH01574: module proxy_module is already loaded, skipping
[Tue Apr 19 11:36:12.054299 2022] [so:warn] [pid 1290] AH01574: module proxy_http_module is already loaded, skipping
[Tue Apr 19 11:36:12.054476 2022] [so:warn] [pid 1290] AH01574: module ssl_module is already loaded, skipping
[Tue Apr 19 11:36:12.054501 2022] [so:warn] [pid 1290] AH01574: module systemd_module is already loaded, skipping
[Tue Apr 19 11:36:12.054541 2022] [so:warn] [pid 1290] AH01574: module cgi_module is already loaded, skipping
[Tue Apr 19 11:36:12.058129 2022] [alias:warn] [pid 1290] AH00671: The Alias directive in /etc/httpd/conf.d/autoindex.conf at line 21 will probably never match because it overlaps an earlier Alias.
[Tue Apr 19 11:36:12.058523 2022] [mime_magic:error] [pid 1290] (2)No such file or directory: AH01515: mod_mime_magic: canât read magic file /etc/httpd/NEVER_EVER_USE
[Tue Apr 19 11:36:12.064838 2022] [lbmethod_heartbeat:notice] [pid 1290] AH02282: No slotmem from mod_heartmonitor
[Tue Apr 19 11:36:12.069656 2022] [mpm_prefork:notice] [pid 1290] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_wsgi/3.4 Python/2.7.5 configured â resuming normal operations
[Tue Apr 19 11:36:12.069682 2022] [core:notice] [pid 1290] AH00094: Command line: â/usr/sbin/httpd -D FOREGROUNDâ
From Dynflow console :
This is a success action example: took neary 24 hours to complete and 4 hours running for just this one.
Queue: default
Started at: 2022-04-19 12:15:40 UTC
Ended at: 2022-04-20 23:22:44 UTC
Real time: 126424.90s
Execution time (excluding suspended state): 13893.61s
Input:
capsule_id: 6
repo_pulp_id: 3-foreman2_3_Proxy-Non-Production-c297a282-c900-491b-87ed-dba70af43020
repository_id: 1403
sync_options:
remove_missing: true
remote_user: admin
remote_cp_user: admin
current_request_id:
current_timezone: Europe/London
current_user_id: 4
current_organization_id: 3
current_location_id: 2
Output:
smart_proxy_history_id: 31460
pulp_tasks:
- exception:
task_type: pulp.server.managers.repo.sync.sync
_href: â/pulp/api/v2/tasks/64489192-6776-4388-9071-9ae33f4f72f0/â
task_id: 64489192-6776-4388-9071-9ae33f4f72f0
tags:- pulp:repository:3-foreman2_3_Proxy-Non-Production-c297a282-c900-491b-87ed-dba70af43020
- pulp:action:sync
finish_time: â2022-04-20T22:41:37Zâ
_ns: task_status
start_time: â2022-04-20T11:22:47Zâ
traceback:
spawned_tasks: - _href: â/pulp/api/v2/tasks/505ebf0f-2d92-4020-8916-cc7f8f5a0a8a/â
task_id: 505ebf0f-2d92-4020-8916-cc7f8f5a0a8a
progress_report:
yum_importer:
content:
items_total: 829
state: FINISHED
error_details:
details:
rpm_total: 829
rpm_done: 829
drpm_total: 0
drpm_done: 0
size_total: 6831914204
size_left: 0
items_left: 0
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
items_total: 0
state: FINISHED
error_details:
items_left: 0
modules:
state: FINISHED
errata:
state: FINISHED
metadata:
state: FINISHED
queue: reserved_resource_worker-7@foreman-proxy.inf.itsystems.global.dq2
state: finished
worker_name: reserved_resource_worker-7@ -foreman-proxy.inf.itsystems.global
result:
result: success
importer_id: yum_importer
exception:
repo_id: 3-foreman2_3_Proxy-Non-Production-c297a282-c900-491b-87ed-dba70af43020
traceback:
started: â2022-04-20T11:22:47Zâ
_ns: repo_sync_results
completed: â2022-04-20T22:41:37Zâ
importer_type_id: yum_importer
error_message:
summary:
modules:
state: FINISHED
content:
state: FINISHED
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
state: FINISHED
errata:
state: FINISHED
metadata:
state: FINISHED
added_count: 3569
removed_count: 0
updated_count: 0
details:
modules:
state: FINISHED
content:
items_left: 0
items_total: 829
state: FINISHED
size_left: 0
details:
rpm_total: 829
rpm_done: 829
drpm_total: 0
drpm_done: 0
error_details:
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
items_total: 0
state: FINISHED
error_details:
items_left: 0
errata:
state: FINISHED
metadata:
state: FINISHED
error:
_id:
â$oidâ: 625ea7ee5f4417acf07a7025
- exception:
task_type: pulp.server.managers.repo.publish.publish
- pulp:action:publish
finish_time: â2022-04-20T23:22:41Zâ
_ns: task_status
start_time: â2022-04-20T23:21:04Zâ
traceback:
spawned_tasks:
progress_report:
3-foreman2_3_Proxy-Non-Production-c297a282-c900-491b-87ed-dba70af43020:- num_success: 1
description: Initializing repo metadata
step_type: initialize_repo_metadata
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: ed79f850-7632-48cc-be39-d404a67a764e
num_processed: 1 - num_success: 0
description: Publishing Distribution files
step_type: distribution
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: 631e9447-60fe-4810-8ba9-99d69b3b98eb
num_processed: 0 - num_success: 3569
description: Publishing RPMs
step_type: rpms
items_total: 3569
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: 6644ccdc-76ff-49fb-b8dc-a9ae908883a6
num_processed: 3569 - num_success: 0
description: Publishing Delta RPMs
step_type: drpms
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
step_id: bcb70b3d-3071-4c98-8ac4-b23d7f040e6b
num_processed: 0 - num_success: 0
description: Publishing Errata
step_type: errata
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: 4d53da87-ee5b-41d4-af17-a8342941be45
description: Publishing Modules
step_type: modules
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
step_id: â04925283-b1ea-4fd6-bbf9-04bfe901b1caâ
description: Publishing Comps file
step_type: comps
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: b72cfdaf-a3fe-42d5-8702-fa2382fada6b
description: Publishing Metadata.
step_type: metadata
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: 8e504874-9c56-4ac4-9aa1-359cc906f11b
num_processed: 0 - num_success: 1
description: Closing repo metadata
step_type: close_repo_metadata
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: d5396a3f-445c-4a6e-b937-faaec70dd1e0
description: Generating sqlite files
step_type: generate sqlite
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
step_id: â0594f177-6d17-40b7-bc66-970968fdb49bâ
description: Removing old repodata
step_type: remove_old_repodata
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: ac5575b1-05f9-496a-a50c-20e8b0b42a7f
description: Generating HTML files
step_type: repoview
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
step_id: 70c7e274-4a72-42a7-9251-e8d90d987e50
description: Publishing files to web
step_type: publish_directory
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: bbffeeca-459b-43f2-8046-176b2dc2f5b7
num_processed: 1 - num_success: 1
description: Writing Listings File
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: f8c57e0d-c34f-482d-a625-2f47e48b05ca
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_id: 79a7e563-5da4-4805-86b3-9fadaa4e9896
num_processed: 1
queue: reserved_resource_worker-7@ -foreman-proxy.inf.itsystems.global.dq2
state: finished
result:
result: success
exception:
started: â2022-04-20T23:21:04Zâ
_ns: repo_publish_results
completed: â2022-04-20T23:22:41Zâ
traceback:
distributor_type_id: yum_distributor
summary:
generate sqlite: SKIPPED
rpms: FINISHED
initialize_repo_metadata: FINISHED
remove_old_repodata: FINISHED
modules: SKIPPED
close_repo_metadata: FINISHED
drpms: SKIPPED
comps: FINISHED
distribution: FINISHED
repoview: SKIPPED
publish_directory: FINISHED
errata: FINISHED
metadata: FINISHED
error_message:
distributor_id: 3-foreman2_3_Proxy-Non-Production-c297a282-c900-491b-87ed-dba70af43020
details: - num_success: 1
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_type: rpms
items_total: 3569
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_type: drpms
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
step_type: errata
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_type: modules
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
step_type: comps
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_type: metadata
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
items_total: 0
state: FINISHED
error_details:
details: ââ
num_failures: 0
step_type: repoview
items_total: 1
state: SKIPPED
error_details:
details: ââ
num_failures: 0
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
items_total: 1
state: FINISHED
error_details:
details: ââ
num_failures: 0
num_processed: 1
error:
_id:
â$oidâ: 62608c215f4417acf01264cf
poll_attempts:
total: 7009
failed: 0
- num_success: 1
**This is an example of Pulpchecking action: **
256: Actions::Pulp::Consumer::SyncCapsule (checking Pulp task status) [ 247913.26s / 34415.13s ] Cancel
Queue: default
Ended at: 2022-04-22 09:07:33 UTC
Real time: 247913.26s
Execution time (excluding suspended state): 34415.13s
Input:
capsule_id: 6
repo_pulp_id: 3-foreman2_3_Proxy-Spacewalk-c297a282-c900-491b-87ed-dba70af43020
repository_id: 1415
sync_options:
remote_user: admin
current_request_id:
current_user_id: 4
Output:
smart_proxy_history_id: 31461
pulp_tasks:
- exception:
_href: â/pulp/api/v2/tasks/d4ccbe8b-e43d-4b59-896d-ce6d19d97ea2/â
task_id: d4ccbe8b-e43d-4b59-896d-ce6d19d97ea2
tags:- pulp:repository:3-foreman2_3_Proxy-Spacewalk-c297a282-c900-491b-87ed-dba70af43020
- pulp:action:sync
finish_time: â2022-04-21T03:45:25Zâ
_ns: task_status
start_time: â2022-04-19T15:58:35Zâ
traceback:
spawned_tasks: - _href: â/pulp/api/v2/tasks/bf8edaa7-565b-4001-92c8-7698661ee895/â
task_id: bf8edaa7-565b-4001-92c8-7698661ee895
progress_report:
yum_importer:
content:
items_total: 3569
state: FINISHED
error_details:
details:
rpm_total: 3569
rpm_done: 3569
drpm_total: 0
drpm_done: 0
size_total: 22939796152
size_left: 0
items_left: 0
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
items_total: 0
state: FINISHED
error_details:
items_left: 0
modules:
state: FINISHED
errata:
state: FINISHED
metadata:
state: FINISHED
queue: reserved_resource_worker-11@ -foreman-proxy.inf.itsystems.global.dq2
state: finished
worker_name: reserved_resource_worker-11@ -foreman-proxy.inf.itsystems.global
result:
result: success
exception:
repo_id: 3-foreman2_3_Proxy-Spacewalk-c297a282-c900-491b-87ed-dba70af43020
traceback:
started: â2022-04-19T15:58:35Zâ
completed: â2022-04-21T03:45:25Zâ
error_message:
summary:
modules:
state: FINISHED
content:
state: FINISHED
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
state: FINISHED
errata:
state: FINISHED
metadata:
state: FINISHED
added_count: 3569
removed_count: 0
updated_count: 0
details:
modules:
state: FINISHED
content:
items_left: 0
items_total: 3569
state: FINISHED
size_left: 0
details:
rpm_total: 3569
rpm_done: 3569
drpm_total: 0
drpm_done: 0
error_details:
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
items_total: 0
state: FINISHED
error_details:
items_left: 0
errata:
state: FINISHED
metadata:
state: FINISHED
error:
_id:
â$oidâ: 625ea7ed5f4417acf07a6fb4
- exception:
finish_time:
_ns: task_status
start_time:
traceback:
spawned_tasks:
progress_report: {}
queue: ââ
state: waiting
worker_name:
result:
error:
_id:
â$oidâ: 6260d3555f4417acf0331ba4
poll_attempts:
total: 13317
failed: 0
** This is Example of Pulp waiting to finish task**
Queue: default
Started at: 2022-04-19 12:15:42 UTC
Ended at: 2022-04-22 09:07:48 UTC
Real time: 247926.75s
Execution time (excluding suspended state): 32441.67s
Input:
capsule_id: 6
repo_pulp_id: 3-Centos6_content-Spacewalk-2a50be50-3052-4790-aa33-d70daff3574a
repository_id: 583
sync_options:
remote_user: admin
current_request_id:
current_user_id: 4
Output:
smart_proxy_history_id: 31474
pulp_tasks:
- exception:
_href: â/pulp/api/v2/tasks/b29fb0ba-be46-40b3-a750-80cc7eaabd21/â
task_id: b29fb0ba-be46-40b3-a750-80cc7eaabd21
tags:- pulp:repository:3-Centos6_content-Spacewalk-2a50be50-3052-4790-aa33-d70daff3574a
- pulp:action:sync
finish_time: â2022-04-21T10:43:45Zâ
_ns: task_status
start_time: â2022-04-20T21:06:48Zâ
traceback:
spawned_tasks: - _href: â/pulp/api/v2/tasks/85590d90-a8a7-4a80-90e0-f6495128d512/â
task_id: 85590d90-a8a7-4a80-90e0-f6495128d512
progress_report:
yum_importer:
content:
items_total: 7428
state: FINISHED
error_details:
details:
rpm_total: 7428
rpm_done: 7428
drpm_total: 0
drpm_done: 0
size_total: 7434395420
size_left: 0
items_left: 0
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
items_total: 4
state: FINISHED
error_details:
items_left: 0
modules:
state: FINISHED
errata:
state: FINISHED
metadata:
state: FINISHED
queue: reserved_resource_worker-2@ -foreman-proxy.inf.itsystems.global.dq2
state: finished
worker_name: reserved_resource_worker-2@ -foreman-proxy.inf.itsystems.global
result:
result: success
exception:
repo_id: 3-Centos6_content-Spacewalk-2a50be50-3052-4790-aa33-d70daff3574a
traceback:
started: â2022-04-20T21:06:48Zâ
completed: â2022-04-21T10:43:45Zâ
error_message:
summary:
modules:
state: FINISHED
content:
state: FINISHED
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
state: FINISHED
errata:
state: FINISHED
metadata:
state: FINISHED
added_count: 7768
removed_count: 0
updated_count: 0
details:
modules:
state: FINISHED
content:
items_left: 0
items_total: 7428
state: FINISHED
size_left: 0
details:
rpm_total: 7428
rpm_done: 7428
drpm_total: 0
drpm_done: 0
error_details:
comps:
state: FINISHED
purge_duplicates:
state: FINISHED
distribution:
items_total: 4
state: FINISHED
error_details:
items_left: 0
errata:
state: FINISHED
metadata:
state: FINISHED
error:
_id:
â$oidâ: 625ea7f05f4417acf07a7153
- exception:
finish_time:
_ns: task_status
start_time:
traceback:
spawned_tasks:
progress_report: {}
queue: ââ
state: waiting
worker_name:
result:
error:
_id:
â$oidâ: 626135615f4417acf051c7d5
poll_attempts:
total: 13440
failed: 0
We did not release pulp3 with katello untill Katello 3.18. I am not sure this is right.
Hi, I was surprised im running pulp 3 on foreman as It wasnât intended.
however Iâve been told that I am. these are the detail from the about page.
Installed Packages
- candlepin-3.1.22-1.el7.noarch
- candlepin-selinux-3.1.22-1.el7.noarch
- foreman-2.3.5-1.el7.noarch
- foreman-cli-2.3.5-1.el7.noarch
- foreman-debug-2.3.5-1.el7.noarch
- foreman-dynflow-sidekiq-2.3.5-1.el7.noarch
- foreman-installer-2.3.5-1.el7.noarch
- foreman-installer-katello-2.3.5-1.el7.noarch
- foreman-postgresql-2.3.5-1.el7.noarch
- foreman-proxy-2.3.5-1.el7.noarch
- foreman-release-2.3.5-1.el7.noarch
- foreman-selinux-2.3.5-1.el7.noarch
- foreman-service-2.3.5-1.el7.noarch
- -foreman.inf.itsystems.global-apache-1.0-1.noarch
- -foreman.inf.itsystems.global-foreman-client-1.0-1.noarch
- -foreman.inf.itsystems.global-foreman-proxy-1.0-1.noarch
- -foreman.inf.itsystems.global-foreman-proxy-client-1.0-1.noarch
- -foreman.inf.itsystems.global-puppet-client-1.0-1.noarch
- -foreman.inf.itsystems.global-qpid-broker-1.0-1.noarch
- -foreman.inf.itsystems.global-qpid-client-cert-1.0-1.noarch
- -foreman.inf.itsystems.global-qpid-router-client-1.0-1.noarch
- -foreman.inf.itsystems.global-qpid-router-server-1.0-1.noarch
- katello-3.18.3-1.el7.noarch
- katello-agent-3.5.4-1.el7.noarch
- katello-ca-consumer-gbh-foreman.inf.itsystems.global-1.0-1.noarch
- katello-certs-tools-2.7.3-1.el7.noarch
- katello-client-bootstrap-1.7.5-1.el7.noarch
- katello-common-3.18.3-1.el7.noarch
- katello-debug-3.18.3-1.el7.noarch
- katello-default-ca-1.0-1.noarch
- katello-host-tools-3.5.4-1.el7.noarch
- katello-host-tools-fact-plugin-3.5.4-1.el7.noarch
- katello-repos-3.18.3-1.el7.noarch
- katello-selinux-3.5.0-1.el7.noarch
- katello-server-ca-1.0-1.noarch
- pulp-admin-client-2.21.5-1.el7.noarch
- pulp-client-1.0-1.noarch
- pulp-deb-plugins-1.10.2-1.el7.noarch
- pulp-docker-plugins-3.2.9-1.el7.noarch
- pulp-katello-1.0.3-1.el7.noarch
- pulp-puppet-plugins-2.21.5-1.el7.noarch
- pulp-puppet-tools-2.21.5-1.el7.noarch
- pulp-rpm-admin-extensions-2.21.5-1.el7.noarch
- pulp-rpm-plugins-2.21.5-1.el7.noarch
- pulp-selinux-2.21.5-1.el7.noarch
- pulp-server-2.21.5-1.el7.noarch
- pulpcore-selinux-1.2.3-2.el7.x86_6
I see this so it should be pulp3 which is rightâŚThe 3.14 threw me off a littleâŚ
I donât know why the capsule syncs would take a day to finishâŚI can imagine some memory constraints. The access log errors donât seem related to capsule syncs. Iâd strongly suggest upgrading to later versions on both the server and the capsule.
Unfortunately Iâm unable to upgrade at this time. My 4 other proxies are fine it just this one.
I didnt know if there were some proxy side tuning settings that could be used or a pulp database clear out of proxy. Could the pulp database be corrupt ?
There donât seem to be any errors on the capule sync itselfâŚIâd check the memory on the capsule. A full capsule sync should fix any corrupt data although the syncs taking a day to finish make that really cumbersome in this case.
Iâd maybe empty the capsule by disassociating all environments from the capsule and running delete orphaned content task against the capsule to empty it out. It will need a full sync after reassociating environments to the capsule once that is done.
@sinewave How much internet bandwidth do you have? If weâre talking about syncing RHEL 7, that repo is ~60gb, it wouldnât be too surprising for it to take a really long time over a slow proxy.
