Hi all,
I'm new to foreman and running into the following problem.
All BareMetal hosts will be discovered in a special IP-Range
(10.100.44.X/24).
During the Provisioning i change the Interface Subnet to a different one
(10.100.46.X/24, IPAM:InternalDB, Bootmode:static, With Start and End of
IP-Rage defined)
When i provision the host manually i change the subnet and have to click
"suggest new", new ip will be picked from the range. All things works well.
But when i create discovery rules, set the subnet and all the other stuff,
and run Auto Provision the new subnet will be showed but the old ip address
from 10.100.44.x will be used for the interface. In this step i can't use
"suggest new" to generate the right IP.
I try already many things but nothing worked.
More Details:
Foreman (1.10.0 and 1.10.1 tested)
Foreman-discovery (4.1.2)
Discovery Rule (search:model ~ "PRIMERGY", HostGroup:test, Hostname:
Server-1-<%= @host.ip.split('.').last %>)
HostGroup test(Subnet:Static(10.100.46.0/24), Domain:HostDomain,OS:…)
SubNet Static(NetworkAddress:10.100.46.0, Networkmask: 255.255.255.0,…,
IPAM:InternalDB, Bootmode:static, With Start and End of IP-Rage defined, )
The AutoProvisioned Host
Server-1-11:
Domain: HostDomain
HostGroup: test
Interface: Subnet Static(10.100.46.0/24) IP-Address:10.11.44.11
Best regards
Susanne
