Auto provisioning: what can go wrong
I would like to use foreman + discovery for bare metal provisioning
(version 1.11).
When I push the button "Auto provision all" in the "Discovered hosts"
section all these nodes reboot (fine), but NO pxelinux.cfg/… file was
created.
Even in debug mode, proxy.log does not show anything about this. That
indicates that the foreman has got some problems here.
(There is no problem with manual provisioning, though. But that takes time.)
Two things:
  • Where can I see what is missing?
  • Wouldn't it be better to warn the user that something is missing than
    rebooting the nodes without effect?
Best regards,
Ulf
> Hello,
> (version 1.11).
> created.
that probably means your subnet doesn't have a tftp proxy associated.
Thats good feedback, and you should probably add it as a feature request on
http://projects.theforeman.org - and of course -patches are welcomed :slight_smile:
thanks!
··· On Wed, Jun 1, 2016 at 3:52 PM, 'Ulf Markwardt' via Foreman users < foreman-users@googlegroups.com> wrote:
time.)
Two things:
  • Wouldn’t it be better to warn the user that something is missing
    than rebooting the nodes without effect?
Best regards,
Ulf
"Foreman users" group.
> - Where can I see what is missing?
In production.log
>> (version 1.11).
>> created.
But it does, I have checked!
Interesting: "Smart Proxy => Services" says "TFTP server false", yet I
can manually provision my hosts.
Mysterious…
