Hi I am in the process of writing an Amazon CloudFormation template that I
hope will eventually be able to spin up a fully configured
Puppetmaster/Passenger/MySQL/ForemanServer/StorconfigsServer, running on
Ubuntu, using the latest version of Foreman from the develop branch, and
the latest version of Puppet from Ruby gems.
I have made a decent start, but have a number of questions.
mysql gem or mysql2 gem with develop branch?
Does storeconfigs work with rails3 (and same question regarding which
mysql gem to use) -
Any thoughts on best practices for installation location for foreman?
/opt/foreman or /var/www/foreman? -
Are there any init.d scripts out there for the develop Foreman (Rails3
version)? -
Is there an easy method to call bundler so that foreman gets installed
with a mysql aware database.yaml? All the instructions I have found have
one manually editing database.yml to switch from sqllite3. -
Should I use the default ruby 1.8.7, or install 1.9 from source? (I
think we aren't fully 1.9 ready yet, if I recall.) -
On a similar line, to use REE or not to use REE?
What user shall I run Foreman as. I'm thinking www-data or foreman?
Any issue with hardcoding Passenger 3.0.11 in the installation? (I need
to hard code some paths into the apache config, and knowing what version of
the gem is installed is a key part of the path.)
10 Any thoughts on what I should ship as a basic puppet manifest? (Haven't
given this much thought yet.)
As an aside, most of this will need to be done via a shell script that will
be embedded in the template, but on the flip side, this will be a good
example on how to install foreman on Ubuntu. (And a good example of
installing a fairly complex server using CloudFormation.)
Brian
