Im am using Foreman with Katello (Foreman 1.15.6 and Katello 3.4.5). Building new hosts with that is working without any problems. The problem is when i try to build an host on other location with a Smart-proxy that is located on othet location.
I allway get the massage:
TFTP prefix:
Unable to locate configuration file.
Status of Smart-proxy is OK and he is synchronized:
Pulp node
Version 1.3.0
Pulp server version 2.13.2
Database connection OK
Messaging connection OK
Workers 4
TFTP
Version 1.15.6
TFTP server “other location SMART-proxy hostname”
Templates
Version 1.15.6
If i set the Proxys in the subnet to TFTP proxy: “other location SMART-proxy hostname” then the build doesent work. If i set it to Foreman then it is working but he gets it from Foreman and not from local smart-proxy???
Foreman 1.15.6 Foreman and Proxy plugin versions:
Foreman 1.15.6, Katello 3.4.5,
Dynflow
Version 0.1.8
Pulp
Version 1.3.0
SSH
Version 0.1.6
TFTP
Version 1.15.6
I changed the PXE helper on local smart-proxy and it is starting to instal the OS.
But now i get the the error:
Failed connect to LOCAL SMART PROXY:8000; Connection refused
dracut-initqueue[553]: Warning: anaconda: failed to fetch kickstart from http://LOCAL SMART PROXY:8000/unattended/provision?token=…
