Failed to delete host due to Unable to delete PuppetCA certififcate for the server.
Actual issue that brought me to this is that at point dracut should download unattended file, it fails and same Certificate issue message is logged. At this point I suspect its an certificate issue for this client, but I am not sure.
Delete the Host, so I can re-create it.
foreman-proxy-1.15.6-1.el7.noarch
foreman-installer-1.15.6-2.el7.noarch
foreman-1.15.6-1.el7.noarch
tfm-rubygem-hammer_cli_foreman-0.10.2-1.el7.noarch
foreman-selinux-1.15.6-1.el7.noarch
tfm-rubygem-foreman-tasks-core-0.1.8-1.fm1_15.el7.noarch
tfm-rubygem-foreman_remote_execution-1.3.7-1.fm1_15.el7.noarch
foreman-postgresql-1.15.6-1.el7.noarch
foreman-cli-1.15.6-1.el7.noarch
tfm-rubygem-foreman_setup-5.0.0-1.fm1_13.el7.noarch
tfm-rubygem-foreman-tasks-0.9.6-1.fm1_15.el7.noarch
tfm-rubygem-foreman_remote_execution_core-1.0.6-1.fm1_15.el7.noarch
foreman-release-1.15.6-1.el7.noarch
foreman-debug-1.15.6-1.el7.noarch
foreman-release-scl-3-1.el7.noarch
Its stand-alone server, installed using foreman-installer with Puppet and hosts are added using Hammer CLI
2019-01-11 14:41:08 8c2665db [app] [W] Delete PuppetCA certificates for autoperf-small01.avinity.tv task failed with the following error: ERF12-7740 [ProxyAPI::ProxyException]: Unable to delete PuppetCA certificate for autoperf-small01.avinity.tv ([RestClient::RequestTimeout]: Request Timeout) for proxy https://mgrun-foreman.avinity.tv:8443/puppet/ca
| ProxyAPI::ProxyException: ERF12-7740 [ProxyAPI::ProxyException]: Unable to delete PuppetCA certificate for autoperf-small01.avinity.tv ([RestClient::RequestTimeout]: Request Timeout) for proxy https://mgrun-foreman.avinity.tv:8443/puppet/ca
2019-01-11 14:41:09 8c2665db [app] [I] Failed to save: Delete PuppetCA certificates for autoperf-small01.avinity.tv task failed with the following error: ERF12-7740 [ProxyAPI::ProxyException]: Unable to delete PuppetCA certificate for autoperf-small01.avinity.tv ([RestClient::RequestTimeout]: Request Timeout) for proxy https://mgrun-foreman.avinity.tv:8443/puppet/ca
2019-01-11 14:42:28 6ddd3019 [app] [I] Started GET "/hosts/autoperf-small01.avinity.tv" for 2a03:fc02:2:1:f961:2f48:3a02:db6 at 2019-01-11 14:42:28 +0000
2019-01-11 14:42:28 6ddd3019 [app] [I] Parameters: {"id"=>"autoperf-small01.avinity.tv"}
2019-01-11 14:42:29 df2ba2ca [app] [I] Started GET "/hosts/autoperf-small01.avinity.tv/overview" for 2a03:fc02:2:1:f961:2f48:3a02:db6 at 2019-01-11 14:42:29 +0000
2019-01-11 14:42:29 df2ba2ca [app] [I] Parameters: {"id"=>"autoperf-small01.avinity.tv"}
2019-01-11 14:42:29 3e133e08 [app] [I] Started GET "/hosts/autoperf-small01.avinity.tv/templates" for 2a03:fc02:2:1:f961:2f48:3a02:db6 at 2019-01-11 14:42:29 +0000
2019-01-11 14:42:29 1e21107b [app] [I] Started GET "/hosts/autoperf-small01.avinity.tv/nics" for 2a03:fc02:2:1:f961:2f48:3a02:db6 at 2019-01-11 14:42:29 +0000
2019-01-11 14:42:29 1e21107b [app] [I] Parameters: {"id"=>"autoperf-small01.avinity.tv"}
2019-01-11 14:42:29 6e37251a [app] [I] Started GET "/hosts/autoperf-small01.avinity.tv/runtime?range=7" for 2a03:fc02:2:1:f961:2f48:3a02:db6 at 2019-01-11 14:42:29 +0000
2019-01-11 14:42:29 6e37251a [app] [I] Parameters: {"range"=>"7", "id"=>"autoperf-small01.avinity.tv"}
2019-01-11 14:42:29 a41a7c24 [app] [I] Started GET "/hosts/autoperf-small01.avinity.tv/resources?range=7" for 2a03:fc02:2:1:f961:2f48:3a02:db6 at 2019-01-11 14:42:29 +0000
2019-01-11 14:42:29 a41a7c24 [app] [I] Parameters: {"range"=>"7", "id"=>"autoperf-small01.avinity.tv"}
2019-01-11 14:42:30 3e133e08 [app] [I] Parameters: {"id"=>"autoperf-small01.avinity.tv"}
2019-01-11 14:53:38 68e0ce72 [app] [W] Delete PuppetCA certificates for autoperf-small01.avinity.tv task failed with the following error: ERF12-7740 [ProxyAPI::ProxyException]: Unable to delete PuppetCA certificate for autoperf-small01.avinity.tv ([RestClient::RequestTimeout]: Request Timeout) for proxy https://mgrun-foreman.avinity.tv:8443/puppet/ca
2019-01-11 14:55:38 44d3eafd [app] [W] Delete PuppetCA certificates for autoperf-small01.avinity.tv task failed with the following error: ERF12-7740 [ProxyAPI::ProxyException]: Unable to delete PuppetCA certificate for autoperf-small01.avinity.tv ([RestClient::RequestTimeout]: Request Timeout) for proxy https://mgrun-foreman.avinity.tv:8443/puppet/ca
