Dependency problems with candlepin’s deps due to re-introduction of tomcat into EL8 repos
No dependency conflicts
Foreman and Proxy versions: 3.7.0
Foreman and Proxy plugin versions: 3.7.0
Distribution and version: CentOS 8-Stream for the last week or so
CentOS 8-stream includes the upcoming changes for RHEL 8 to re-include tomcat, which seems to conflict with previous dependencies that candlepin depends on. Thus, current CentOS 8-stream says the following with unqualified yum upgrade:
Error:
Problem: cannot install the best update candidate for package pki-servlet-engine-1:9.0.30-3.module_el8.5.0+854+e1c92b81.noarch
- both package tomcat-el-3.0-api-1:9.0.62-12.el8.noarch from imladris_cs_8_x86_64_appstream and tomcat-lib-1:9.0.62-12.el8.noarch from imladris_cs_8_x86_64_appstream obsolete pki-servlet-engine
- package tomcat-jsp-2.3-api-1:9.0.62-12.el8.noarch from imladris_cs_8_x86_64_appstream requires tomcat-servlet-4.0-api = 1:9.0.62-12.el8, but none of the providers can be installed
- package tomcat-lib-1:9.0.62-12.el8.noarch from imladris_cs_8_x86_64_appstream requires tomcat-servlet-4.0-api = 1:9.0.62-12.el8, but none of the providers can be installed
- package tomcat-servlet-4.0-api-1:9.0.62-12.el8.noarch from imladris_cs_8_x86_64_appstream is filtered out by modular filtering
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
Doubtless this will be a complication for IdM/FreeIPA too, just wanted to report it here so it would be on the “radar” if it isn’t already
Thanks. We are aware and are coordinating with the team that manages the Tomcat packages. Right now the workaround to update a system hitting this error is to use --nobest so that it skips the Tomcat related packages and allows the rest of the packages to update.
Update: CentOS Stream 8 has fixed the Tomcat issue by cleaning up the bad packages and now updates of the system should be able to proceed as normal. That is, --nobest is no longer required.
The issue seems to still haunt my Foreman server. If the issue is resolved, how can I work out why I’m still seeing this issue?
user@fm01:~$ sudo dnf list --showduplicates tomcat [352/352]
Last metadata expiration check: 0:02:34 ago on Wed 24 Jan 2024 19:46:40 CET.
Installed Packages
tomcat.noarch 1:9.0.62-12.el8 @appstream
Available Packages
tomcat.noarch 1:9.0.62-14.el8 appstream
tomcat.noarch 1:9.0.62-27.el8 appstream
tomcat.noarch 1:9.0.62-29.el8 appstream
user@fm01:~$ sudo dnf update tomcat
CentOS Stream 8 - AppStream 22 kB/s | 4.4 kB 00:00
Error:
Problem: problem with installed package candlepin-4.3.1-1.el8.noarch
- package candlepin-4.3.1-1.el8.noarch from @System requires pki-servlet-engine, but none of the providers can be installed
- package candlepin-4.3.1-1.el8.noarch from katello-candlepin requires pki-servlet-engine, but none of the providers can be installed
- package tomcat-1:9.0.62-29.el8.noarch from appstream conflicts with pki-servlet-engine <= 1:9.0.50 provided by tomcat-1:9.0.62-12.el8.noarch from @System
- cannot install both tomcat-1:9.0.62-29.el8.noarch from appstream and tomcat-1:9.0.62-12.el8.noarch from @System
- package tomcat-1:9.0.62-29.el8.noarch from appstream conflicts with pki-servlet-engine <= 1:9.0.50 provided by pki-servlet-engine-1:9.0.30-1.module_el8.4.0+595+e59c9af2.noarch from appstream
- package tomcat-1:9.0.62-29.el8.noarch from appstream conflicts with pki-servlet-engine <= 1:9.0.50 provided by pki-servlet-engine-1:9.0.30-3.module_el8.5.0+854+e1c92b81.noarch from appstream
- cannot install the best update candidate for package tomcat-1:9.0.62-12.el8.noarch
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
