The webui is working , but when I try to add a yum repository to a product the following message is displayed:
"There was an issue with the backend service pulp: 500 Internal Server Error"
The smartproxy is running on the same server as foreman , iptables and selinux disabled
Running the foreman-service status I see the following errors.
/usr/sbin/service-wait pulp_resource_manager status
● pulp_resource_manager.service - Pulp Resource Manager
Loaded: loaded (/usr/lib/systemd/system/pulp_resource_manager.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2017-12-09 22:29:35 CET; 1h 26min ago
Process: 1186 ExecStart=/usr/bin/celery worker -A pulp.server.async.app -n resource_manager@%%h -Q resource_manager -c 1 --events --umask 18 --pidfile=/var/run/pulp/resource_manager.pid (code=exited, st atus=1/FAILURE)
Main PID: 1186 (code=exited, status=1/FAILURE)
Dec 09 22:29:35 v1c2c02.mst.proxy.nl celery[1186]: File
"/usr/lib/python2.7/site-packages/pulp/plugins/loader/manager.py", line 9, in <module>
Dec 09 22:29:35 v1c2c02.mst.proxy.nl celery[1186]: from
pulp.server.db.model import ContentUnit
"/usr/lib/python2.7/site-packages/pulp/server/db/model/__init__.py", line 33, in <module>
pulp.server.webservices.views import serializers
"/usr/lib/python2.7/site-packages/pulp/server/webservices/views/serializers/__init__.py", line 4, in <module>
django.core.urlresolvers import reverse
Dec 09 22:29:35 v1c2c02.mst.proxy.nl celery[1186]: ImportError: No module named django.core.urlresolvers
Dec 09 22:29:35 v1c2c02.mst.proxy.nl systemd[1]:
pulp_resource_manager.service: main process exited, code=exited, status=1/FAILURE
Dec 09 22:29:35 v1c2c02.mst.proxy.nl systemd[1]: Unit
pulp_resource_manager.service entered failed state.
pulp_resource_manager.service failed.
/usr/sbin/service-wait pulp_streamer status
● pulp_streamer.service - The Pulp lazy content loading streamer Loaded: loaded (/usr/lib/systemd/system/pulp_streamer.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2017-12-09 22:29:36 CET; 1h 26min ago
Process: 1193 ExecStart=/usr/bin/pulp_streamer --nodaemon --syslog --prefix=pulp_streamer --pidfile= --python
/usr/share/pulp/wsgi/streamer.tac (code=exited, status=1/FAILURE) Main PID: 1193 (code=exited, status=1/FAILURE)
Dec 09 22:29:36 v1c2c02.mst.proxy.nl pulp_streamer[1193]: from pulp.server.db.model import Worker, ReservedResource, TaskStatus, \ Dec 09 22:29:36 v1c2c02.mst.proxy.nl pulp_streamer[1193]: File "/usr/lib/python2.7/site-packages/pulp/server/db/model/__init__.py", line 33, in <module>
Dec 09 22:29:36 v1c2c02.mst.proxy.nl pulp_streamer[1193]: from pulp.server.webservices.views import serializers
Dec 09 22:29:36 v1c2c02.mst.proxy.nl pulp_streamer[1193]: File "/usr/lib/python2.7/site-packages/pulp/server/webservices/views/serializers/__init__.py", line 4, in <module>
Dec 09 22:29:36 v1c2c02.mst.proxy.nl pulp_streamer[1193]: from django.core.urlresolvers import reverse
exceptions.ImportError: No module named django.core.urlresolvers Dec 09 22:29:36 v1c2c02.mst.proxy.nl pulp_streamer[1193]: Failed to load application: No module named django.core.urlresolvers
Dec 09 22:29:36 v1c2c02.mst.proxy.nl systemd[1]: pulp_streamer.service: main process exited, code=exited, status=1/FAILURE
Dec 09 22:29:36 v1c2c02.mst.proxy.nl systemd[1]: Unit pulp_streamer.service entered failed state.
Dec 09 22:29:36 v1c2c02.mst.proxy.nl systemd[1]: pulp_streamer.service failed.
Systemctl for the pulp services:
● pulp_celerybeat.service loaded failed failed Pulp's Celerybeat
● pulp_resource_manager.service loaded failed failed Pulp Resource Manager
● pulp_streamer.service loaded failed failed The Pulp lazy content loading streamer
● pulp_worker-0.service loaded failed failed Pulp Worker #0
● pulp_worker-1.service loaded failed failed Pulp Worker #1
● pulp_worker-2.service loaded failed failed Pulp Worker #2
● pulp_worker-3.service loaded failed failed Pulp Worker #3
pulp_workers.service loaded active exited Pulp Celery Workers
Regards.
Mike Hulsman
I found the solution for this.
When installing with: foreman-installer --scenario katello the
rpm python-django16-1.6.11.6-6.el7.noarch is installed.
That is given the error exceptions.ImportError: No module named
When you manually install the rpm python-django-1.6.11.6-1.el7.noarch all
the pulp workers are starting and no 500 Internal Server Errors appear.
Regard.
Mike Hulsman
On Sunday, December 10, 2017 at 10:15:23 AM UTC+1, Mike Hulsman wrote:
In a fresh install on CentOS 7.4 pulp is not working.
“There was an issue with the backend service pulp: 500 Internal Server
Error”The smartproxy is running on the same server as foreman , iptables and
selinux disabledRunning the foreman-service status I see the following errors.
1h 26min ago
–pidfile=/var/run/pulp/resource_manager.pid (code=exited, st
atus=1/FAILURE)
Main PID: 1186 (code=exited, status=1/FAILURE)Dec 09 22:29:35 v1c2c02.mst.proxy.nl celery[1186]: File
in
"/usr/lib/python2.7/site-packages/pulp/server/db/model/init.py", line
33, in
"/usr/lib/python2.7/site-packages/pulp/server/webservices/views/serializers/init.py",
line 4, in
status=1/FAILURE
1h 26min ago
–prefix=pulp_streamer --pidfile= --python
Main PID: 1193 (code=exited, status=1/FAILURE)Dec 09 22:29:36 v1c2c02.mst.proxy.nl pulp_streamer[1193]: from
33, in
line 4, in
failed.Systemctl for the pulp services:
loaded failed failed Pulp’s
Celerybeat
Resource Manager
Worker #0
Worker #1
Worker #2
Worker #3
Celery WorkersRegards.
Mike Hulsman
