On a fresh install of Foreman 2.2.1 and Katello 3.17 some of the repositories I created and published in a content view doesn’t appear in the redhat.repo of Centos 8 clients.
No problem to sync the repo nor to publish and promote content view to the Lifecycle env.
The 2 problematics repos are Centos 8 Appstream from:
and MariaDB 10.5 from:
Publishing a other repo after this 2 in the content view didn’t cause any troubles. It appears on clients.
Can you perhaps have a look at https://bugzilla.redhat.com/show_bug.cgi?id=1886325 if it could be the same problem that hits you? I am still searching for a reproducer or something else to drive this forward.
Seems to be the same bug happens here, except in my case that is Centos8 who is involved. My Centos 7 repo are all well published to hosts.
No workaround for now?
Unfortunately no, as Candlepin guys need a way to reproduce and I can not find a way to reproduce it, but perhaps with more data in the bug report someone can find a pattern.
