Mismatching rpm packages performing “yum update” on CentOS 8 for latest foreman.
# yum update
Last metadata expiration check: 2:45:55 ago on Mon 06 Jul 2020 15:58:04 UTC.
Error:
Problem: package foreman-2.1.0-1.el8.noarch requires rubygem(net-ssh) = 4.2.0, but none of the providers can be installed
- cannot install both rubygem-net-ssh-5.1.0-2.el8.noarch and rubygem-net-ssh-4.2.0-2.el8.noarch
- cannot install both rubygem-net-ssh-4.2.0-2.el8.noarch and rubygem-net-ssh-5.1.0-2.el8.noarch
- cannot install the best update candidate for package rubygem-net-ssh-4.2.0-2.el8.noarch
- cannot install the best update candidate for package foreman-2.1.0-0.22.rc3.el8.noarch
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
On initial installation the foreman-installer script clearly deploys rubygem-net-ssh from the foreman repo and not later version seeminly available from epel repo. This does not appear to be an issue for initial deployment.
“yum update” today displays a mismatch in rpm versions as above.
The mismatch appears to come from differing versions in foreman and epel repo:
# yum list | grep rubygem-net-ssh
rubygem-net-ssh.noarch 4.2.0-2.el8 @foreman
rubygem-net-ssh.noarch 5.1.0-2.el8 epel
rubygem-net-ssh-doc.noarch 5.1.0-2.el8 epel
rubygem-net-ssh-gateway.noarch 1.2.0-6.el8 foreman-plugins
rubygem-net-ssh-gateway-doc.noarch 1.2.0-6.el8 foreman-plugins
rubygem-net-ssh-krb.noarch 0.4.0-3.el8 foreman-plugins
rubygem-net-ssh-krb-doc.noarch 0.4.0-3.el8 foreman-plugins
rubygem-net-ssh-multi.noarch 1.2.0-9.el8 foreman-plugins
rubygem-net-ssh-multi-doc.noarch 1.2.0-9.el8 foreman-plugins
Update successfuly resolves rpm dependencies and matches successfully.
Updating from foreman-2.1.0-0.22.rc3.el8.noarch to latest published foreman-2.1.0-1.el8
n/a
CentOS Linux release 8.2.2004
Conflicting package existing in EPEL repo. As no other packages are required from EPEL to complete update, a suitable workaround to permit update is to temporarily disable the epel 8 repo.
After editing /etc/yum/repos.d/epel.repo “enabled=0” a “yum update” elicits the following and completes correctly:
# yum update
Last metadata expiration check: 0:11:46 ago on Mon 06 Jul 2020 18:44:37 UTC.
Dependencies resolved.
Package Architecture Version Repository Size
Upgrading:
foreman noarch 2.1.0-1.el8 foreman 37 M
foreman-cli noarch 2.1.0-1.el8 foreman 25 k
foreman-debug noarch 2.1.0-1.el8 foreman 31 k
foreman-dynflow-sidekiq noarch 2.1.0-1.el8 foreman 27 k
foreman-installer noarch 1:2.1.0-1.el8 foreman 1.7 M
foreman-postgresql noarch 2.1.0-1.el8 foreman 26 k
foreman-proxy noarch 2.1.0-1.el8 foreman 156 k
foreman-release noarch 2.1.0-1.el8 foreman 12 k
foreman-selinux noarch 2.1.0-1.el8 foreman 54 k
foreman-service noarch 2.1.0-1.el8 foreman 27 k
rubygem-dynflow noarch 1.4.6-1.fm2_1.el8 foreman 372 k
rubygem-foreman_maintain noarch 1:0.6.6-1.el8 foreman 155 k
Installing dependencies:
cyrus-sasl x86_64 2.1.27-1.el8 BaseOS 96 k
cyrus-sasl-gssapi x86_64 2.1.27-1.el8 BaseOS 49 k
libvirt-libs x86_64 4.5.0-42.module_el8.2.0+320+13f867d7 AppStream 4.1 M
nmap-ncat x86_64 2:7.70-5.el8 AppStream 237 k
rubygem-ruby-libvirt x86_64 0.7.1-1.el8 foreman 91 k
rubygem-xmlrpc noarch 0.3.0-105.module_el8.1.0+214+9be47fd7 AppStream 81 k
yajl x86_64 2.1.0-10.el8 AppStream 41 k
Transaction Summary
Install 7 Packages
Upgrade 12 Packages
Per above, after temporarily disabling epel we see that rubygem-net-ssh is installed from the foreman repo and not epel and completes correctly.
