CentOS clients not recieving minor OS upgrade
CentOS 8.1.1911 clients are not getting upgrade to CentOS 8.2.2004
yum or dnf update and upgrade to latest OS minor
Katello 3.15.3.1
Foreman is CentOS 7, clients are CentOS 8.
Foreman Syncs repos from http://mirror.[randommirror].com/8/BaseOS/x86_64/os/, also had it attempting to sync to /8.2.2004/BaseOS/x86_64/os/ and still not seeing an upgrade available. Packages sync without a problem though.
I pretty sure I’m doing something wrong and I’m not sure where to start, thank you!
Are you creating a new version of the Content View for CentOS 8 and publishing it?
Hi @dpoulson,
That was the issue. I was so used to applying errata that it would publish and increment that I forgot I need to kick one off when new packages sync. Thank you!
