Sorry, I don't think I follow. Where is this list coming from,
what would you expect?
On 04/02, Jorick Astrego wrote:
> Met vriendelijke groet, With kind regards,
> Jorick Astrego
> Netbulae Virtualization Experts
> Tel: 053 20 30 270 info@netbulae.eu Staalsteden 4-3A KvK 08198180
> Fax: 053 20 30 271 www.netbulae.eu 7547 TA Enschede BTW NL821234584B01
> To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com.
> Visit this group at http://groups.google.com/group/foreman-users.
Well CentOS has a versioning number of 7.0.1406 and 7.1.1503. When I
don't use these numbers and use 7.0 and 7.1, the normal Centos
installation source fails as the path cannot be found @ http://mirror.centos.org/centos/$version/os/$arch
So I used Major 7 and minor 1.1503, but when the servers check in with
their puppet facts the OS is set to 7.1 and the foreman then creates a
new OS 7.1 and assigns the hosts to that. So I end up with Operating
System CentOS 7.0, 7.1, 7.0.1406 and CentOS 7.1.1503. And the hostgroups
I assigned to use Centos 7.1.1503 are assigned to 7.1 wich messes up the
associations.
I could be doing it wrong so that's why I ask I hope this sheds some
more light on it.
Jorick Astrego
>> Hi,
>> Due to the fact that CentOS doesn't use a normal versioning scheme, I
>> get the following list of operating systems:
>> Name
>> Hosts
>> Centos CentOS 7.0.1406
>> 0 Delete
>> Centos CentOS 7.0
>> 2 Delete
>> Centos CentOS 7.1.1503
>> 2 Delete
>> Centos CentOS 7.1
>> 1 Delete
>> Centos CentOS 6.6
>> 1 Delete
>> Any way to do this properly?
Are there any insights on this problem? I'm about to start deploying
CentOS 7 VMs and just found the disconnect between what Foreman derives
from facter and what the true OS is. Thanks
> >> Hi,
> >> Name
> >> Hosts
> https://deployen.netbulae.mgmt/operatingsystems?order=hosts_count+DESC>
> https://deployen.netbulae.mgmt/operatingsystems/2-CentOS%207-0-1406/edit>
> >> 0 Delete
> https://deployen.netbulae.mgmt/operatingsystems/2-CentOS%207-0-1406>
> >> Centos CentOS 7.0
> https://deployen.netbulae.mgmt/operatingsystems/7-CentOS%207-0/edit>
> >> 2 Delete
> https://deployen.netbulae.mgmt/operatingsystems/6-CentOS%207-1-1503/edit>
> >> 2 Delete
> https://deployen.netbulae.mgmt/operatingsystems/6-CentOS%207-1-1503>
> >> Centos CentOS 7.1
> https://deployen.netbulae.mgmt/operatingsystems/8-CentOS%207-1/edit>
> >> 1 Delete
> >> Centos CentOS 6.6
> https://deployen.netbulae.mgmt/operatingsystems/1-CentOS%206-6/edit>
> >> 1 Delete
> The url is http://mirror.centos.org/centos/7.1.1503/
> associations.
> I could be doing it wrong so that's why I ask ;-) I hope this sheds some
> more light on it.
> Jorick Astrego
> *Netbulae Virtualization Experts *
> Tel: 053 20 30 270 in...@netbulae.eu Staalsteden 4-3A KvK
> 08198180 Fax: 053 20 30 271 www.netbulae.eu 7547 TA Enschede BTW
> NL821234584B01
