We're currently working, slowly, on preparing ourselves to upgrade from
Puppet 3.
In historic bad practice, there are a number of poorly chosen parameter
names in our code. We have been able to fix issues with bad formatting,
names, etc, but we're hitting an issue.
From Puppet 4, parameters must not start with a capital letter.
Unfortunately many of ours do. We can easily fix this on the Puppet side,
but while foreman is case-aware, it does not seem to be case-sensitive. We
are therefore inable to import new, decapitalised variable names into
Foreman.
We somehow need to import these new parameters and persist overrides set on
them.
The planned workflow was (assuming a bad parameter called "BadParam":
-> Declare new parameter name in Puppet (ie, define "badparam") -> Copy all
overrides manually from "BadParam" to "badparam" -> Delete "BadParam" from
puppet, and switch all templates/other usages to use "badparam"
We can't go with this, since importing two parameter names with just a
difference in case won't work.
I'm not sure whether this is a design in Puppet or Foreman.
I'd really appreciate suggestions how we'd be able to achieve our goal.
We'd rather avoid having to entirely change the parameter name.
Thank you in advance for any advice, and let me know if I'm missing any
information needed.
You could work around this by renaming the parameters in foreman itself
using the foreman-console.
Something like:
LookupKey.unscoped.all.each{|key| key.key.downcase!; key.save}
should change the saved names of all class parameters to lowercase.
Of course the puppetclasses should still be modified to look for the lower
case version of the parameter.
On Mon, Jul 31, 2017 at 1:54 PM, 'Tom Farrow' via Foreman users < foreman-users@googlegroups.com> wrote:
We’re currently working, slowly, on preparing ourselves to upgrade from
Puppet 3.
names, etc, but we’re hitting an issue.
Foreman.
on them.
The planned workflow was (assuming a bad parameter called “BadParam”:
→ Declare new parameter name in Puppet (ie, define “badparam”) → Copy
all overrides manually from “BadParam” to “badparam” → Delete “BadParam”
from puppet, and switch all templates/other usages to use “badparam”
We can’t go with this, since importing two parameter names with just a
difference in case won’t work.
I’m not sure whether this is a design in Puppet or Foreman.
I’d really appreciate suggestions how we’d be able to achieve our goal.
We’d rather avoid having to entirely change the parameter name.
Thank you in advance for any advice, and let me know if I’m missing any
information needed.
“Foreman users” group.
Have a nice day,
Tomer Brisker
Red Hat Engineering
This is a very interesting and viable option, thank you.
Would you perhaps know of a way to use this to change a single parameter
override at a time? Note that we use some parameter names across multiple
classes, so I would want to be very specific.
> Something like:
> On Mon, Jul 31, 2017 at 1:54 PM, 'Tom Farrow' via Foreman users < > forema...@googlegroups.com > wrote:
>> Hi,
>> Puppet 3.
>> Foreman.
>> on them.
>> all overrides manually from "BadParam" to "badparam" -> Delete "BadParam"
>> from puppet, and switch all templates/other usages to use "badparam"
>> information needed.
>> "Foreman users" group.
>> Visit this group at https://groups.google.com/group/foreman-users.
> Have a nice day,
> Tomer Brisker
> Red Hat Engineering
You could do something like:
param = PuppetclassLookupKey.search_for('puppetclass = myclass and
key=MyParam').first
param.key.downcase!
param.save
On Mon, Jul 31, 2017 at 4:34 PM, 'Tom Farrow' via Foreman users < foreman-users@googlegroups.com> wrote:
Something like:
lower case version of the parameter.
On Mon, Jul 31, 2017 at 1:54 PM, ‘Tom Farrow’ via Foreman users < >> forema...@googlegroups.com> wrote:
Puppet 3.
Foreman.
on them.
information needed.
Groups “Foreman users” group.
an email to foreman-user...@googlegroups.com.
To post to this group, send email to forema...@googlegroups.com.
Have a nice day,
Tomer Brisker
Red Hat Engineering
Have a nice day,
Tomer Brisker
Red Hat Engineering
