We have a number of legacy Oracle Linux 7 clients that show “Reboot required” after update and reboot. It persists whether rebooted manually or by remote execution. This is new with foreman 1.23.0/katello 3.13.0. The problem does not exist with Oracle Linux 6 or CentOS 7.
Indication clears after reboot.
Foreman 1.23.0 - Katello 3.13.0
Could we have a screenshot of where “Reboot required” is popping up? This is a feature of katello-host-tools-tracer, do you have that installed on your hosts?
All of the depicted OL7 systems have been rebooted by remote execution and have no pending reboots. The system “mpl02-app01-mpl02.internal” has been rebooted, both manually and via remote execution, but still shows “Reboot required.”
Which version of katello-host-tools-tracer do you have installed? Did you rebuild it for OracleLinux? It’s supposed to install a cronjob to upload a tracer after reboot but perhaps that’s not happening or failing.
Yes, it is executing. All were installed from RPM have worked for three years. This failure to accurately reflect reboot status is a new occurrence.The versions are:
