after using Foreman successful on our clusters for more than a year. I'd like to reinstall a 90 node cluster with Centos 7.4. It's now running on Centos 7.3 . I'm not able to just update to 7.4 because of zfsonlinux dependencies and well - some nodes died and had to bare metal install them.
So I was able to install these nodes successfully by pxe-booting and using a regular CentOS mirror. After the final reboot the nodes g ot no network connection at all and puppet wasn't able to pull of course. After logging in locally and restart NetworkManager the connection came up - sometimes on the first try sometimes on the second try. I never discovered such behavior with Centos 7.3 or 7.2.
Network properties:
DHCP, MTU 9000
DHCP-Server not Foreman managed, on different network
TFTP-Server Foreman managed, on different network
I've read one thread on stackexchange which describes a simular problem using a kickstart installation and dhcp network configuration on Centos 7.4
Does any body of you discovered similar problems?
This is what my provisioning template / kickstart template looks like:
install
url --url http://mirror.centos.org/centos/7.4.1708/os/x86_64 --proxy=http://proxy.uni-leipzig.de:3128 lang en_US.UTF-8
selinux --enforcing
keyboard de
skipx
network --bootproto dhcp --hostname galaxy110.sc.uni-leipzig.de --device=somemacaddress rootpw --iscrypted foo
firewall --service=ssh
authconfig --useshadow --passalgo=SHA256 --kickstart
timezone --utc Europe/Berlin
services --disabled gpm,sendmail,cups,pcmcia,isdn,rawdevices,hpoj,bluetooth,openibd,avahi-daemon,avahi-dnsconfd,hidd,hplip,pcscd
bootloader --location=mbr --append="nofb quiet splash=quiet"
zerombr
clearpart --initlabel --all
ignoredisk --only-use=sda
part biosboot --size 1 --fstype=biosboot --asprimary
part / --fstype=xfs --size=20480 --asprimary --ondisk=sda
part swap --size=131072 --ondisk=sda
part /var/log --fstype=xfs --size=10240 --ondisk=sda
part /home --fstype=xfs --size=10240 --grow --ondisk=sda
text
reboot
%packages
yum
dhclient
ntp
wget
@Core
redhat-lsb-core
%end
%post --nochroot
exec < /dev/tty3 > /dev/tty3
#changing to VT 3 so that we can see whats going on....
/usr/bin/chvt 3
cp -va /etc/resolv.conf /mnt/sysimage/etc/resolv.conf
/usr/bin/chvt 1
) 2>&1 | tee /mnt/sysimage/root/install.postnochroot.log
%end
%post
logger "Starting anaconda galaxy110.sc.uni-leipzig.de postinstall" exec < /dev/tty3 > /dev/tty3
/usr/bin/chvt 3
#update local time
echo "updating system time"
/usr/sbin/ntpdate -sub 139.18.1.2
/usr/sbin/hwclock --systohc
# Yum proxy
echo 'proxy = http://proxy.uni-leipzig.de:3128' >> /etc/yum.conf
rpm -Uvh --httpproxy proxy.uni-leipzig.de --httpport 3128 https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
# update all the base packages from the updates repository
if [ -f /usr/bin/dnf ]; then
dnf -y update
else
yum -t -y update
fi
# SSH keys setup snippet for Remote Execution plugin
## Parameters:
# remote_execution_ssh_keys: public keys to be put in ~/.ssh/authorized_keys #
# remote_execution_ssh_user: user for which remote_execution_ssh_keys will be # authorized
# remote_execution_create_user: create user if it not already existing #
# remote_execution_effective_user_method: method to switch from ssh user to # effective user
# This template sets up SSH keys in any host so that as long as your public # SSH key is in remote_execution_ssh_keys, you can SSH into a host. This only # works in combination with Remote Execution plugin.
# The Remote Execution plugin queries smart proxies to build the # remote_execution_ssh_keys array which is then made available to this template # via the host's parameters. There is currently no way of supplying this # parameter manually.
# See http://projects.theforeman.org/issues/16107 for details.
rpm -Uvh --httpproxy proxy.uni-leipzig.de --httpport 3128 https://yum.puppetlabs.com/puppetlabs-release-pc1-el-7.noarch.rpm
dnf -y install puppet-agent
else
yum -t -y install puppet-agent
fi
cat > /etc/puppetlabs/puppet/puppet.conf << EOF
[main]
vardir = /opt/puppetlabs/puppet/cache
logdir = /var/log/puppetlabs/puppet
rundir = /var/run/puppetlabs
ssldir = /etc/puppetlabs/puppet/ssl
[agent]
pluginsync = true
report = true
ignoreschedules = true
ca_server = urzlxdeploy.rz.uni-leipzig.de
certname = galaxy110.sc.uni-leipzig.de
environment = production
EOF
puppet_unit=puppet
/usr/bin/systemctl list-unit-files | grep -q puppetagent && puppet_unit=puppetagent /usr/bin/systemctl enable ${puppet_unit}
/sbin/chkconfig --level 345 puppet on
# export a custom fact called 'is_installer' to allow detection of the installer environment in Puppet modules export FACTER_is_installer=true
# passing a non-existent tag like "no_such_tag" to the puppet agent only initializes the node /opt/puppetlabs/bin/puppet agent --config /etc/puppetlabs/puppet/puppet.conf --onetime --tags no_such_tag --server urzlxdeploy.rz.uni-leipzig.de --no-daemonize
sync
# Inform the build system that we are done.
echo "Informing Foreman that we are built"
wget -q -O /dev/null --no-check-certificate http://urzlxdeploy.rz.uni-leipzig.de/unattended/built ) 2>&1 | tee /root/install.post.log
exit 0
%end
Thanks in advance for your suggestions.
Cheers,
Vadim
Vadim Bulst
Universität Leipzig / URZ
04109 Leipzig, Augustusplatz 10
phone: +49-341-97-33380
mail: vadim.bulst@uni-leipzig.de
