**Problem:Setting up the Provisioning with DHCP and DNS
**Expected outcome: Provisioning setup and able to allow me to start provisioning servers, VMs etc…
**Foreman and Proxy versions:3.9.1
**Foreman and Proxy plugin versions: 3.9.1
I tried to set up provisioning with DHCP and DNS and when I run the foreman-installer stuff it shows at it has successfully installed, but as soon as click Next on that page I get the infamous ‘undefined method value' for nil:NilClass' error (NoMethodError): undefined method
value’ for nil:NilClass
[root@xor-p-foreman01 foreman-installer]# foreman-rake errors:fetch_log request_id=77934b14
Foreman version: 3.9.1
Plugins:
- foreman_dhcp_browser 0.0.8
- foreman_puppet 6.2.0
- foreman_setup 8.0.1
2024-02-16T12:06:03 [I|app|77934b14] Started POST "/foreman_setup/provisioners/1/step4" for 172.21.68.185 at 2024-02-16 12:06:03 -0800
2024-02-16T12:06:03 [I|app|77934b14] Processing by ForemanSetup::ProvisionersController#step4 as HTML
2024-02-16T12:06:03 [I|app|77934b14] Parameters: {"authenticity_token"=>"2O9zQVtis0dz0Nu2c-EPT2ZEzNPx00BplnnyL_gf3MDC61B9bRijyj82LthCemoI9Vpn2hwkwnRv-ELlquHmSQ", "id"=>"1"}
2024-02-16T12:06:03 [I|aud|77934b14] Hostgroup (1) update event on subnet_id , 2
2024-02-16T12:06:03 [I|aud|77934b14] Subnet (2) update event on dhcp_id , 1
2024-02-16T12:06:03 [I|aud|77934b14] Subnet (2) update event on tftp_id , 1
2024-02-16T12:06:03 [I|aud|77934b14] Subnet (2) update event on dns_id , 1
2024-02-16T12:06:03 [W|app|77934b14] undefined method `value' for nil:NilClass
2024-02-16T12:06:03 [I|app|77934b14] Backtrace for 'undefined method `value' for nil:NilClass' error (NoMethodError): undefined method `value' for nil:NilClass
77934b14 | /usr/share/gems/gems/foreman_setup-8.0.1/app/controllers/foreman_setup/provisioners_controller.rb:95:in `step4'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/abstract_controller/base.rb:228:in `process_action'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal/rendering.rb:30:in `process_action'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
77934b14 | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
77934b14 | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
77934b14 | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
77934b14 | /usr/share/gems/gems/audited-5.4.2/lib/audited/sweeper.rb:16:in `around'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/callbacks.rb:137:in `run_callbacks'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/abstract_controller/callbacks.rb:41:in `process_action'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal/rescue.rb:22:in `process_action'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/notifications.rb:203:in `block in instrument'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/notifications.rb:203:in `instrument'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
77934b14 | /usr/share/gems/gems/activerecord-6.1.7.6/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/abstract_controller/base.rb:165:in `process'
77934b14 | /usr/share/gems/gems/actionview-6.1.7.6/lib/action_view/rendering.rb:39:in `process'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal.rb:190:in `dispatch'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_controller/metal.rb:254:in `dispatch'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/routing/route_set.rb:33:in `serve'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/journey/router.rb:50:in `block in serve'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/journey/router.rb:32:in `each'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/journey/router.rb:32:in `serve'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/routing/route_set.rb:842:in `call'
77934b14 | /usr/share/gems/gems/apipie-dsl-2.6.1/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
77934b14 | /usr/share/gems/gems/apipie-rails-1.2.3/lib/apipie/static_dispatcher.rb:68:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/static.rb:24:in `call'
77934b14 | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
77934b14 | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
77934b14 | /usr/share/gems/gems/apipie-rails-1.2.3/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/tempfile_reaper.rb:15:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/etag.rb:27:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/conditional_get.rb:40:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/head.rb:12:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/http/content_security_policy.rb:19:in `call'
77934b14 | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/session/abstract/id.rb:266:in `context'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/session/abstract/id.rb:260:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/cookies.rb:697:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/callbacks.rb:98:in `run_callbacks'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
77934b14 | /usr/share/gems/gems/railties-6.1.7.6/lib/rails/rack/logger.rb:37:in `call_app'
77934b14 | /usr/share/gems/gems/railties-6.1.7.6/lib/rails/rack/logger.rb:28:in `call'
77934b14 | /usr/share/gems/gems/sprockets-rails-3.4.2/lib/sprockets/rails/quiet_assets.rb:13:in `call'
77934b14 | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
77934b14 | /usr/share/gems/gems/request_store-1.5.1/lib/request_store/middleware.rb:19:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/request_id.rb:26:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/method_override.rb:24:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/runtime.rb:22:in `call'
77934b14 | /usr/share/gems/gems/activesupport-6.1.7.6/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/executor.rb:14:in `call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/sendfile.rb:110:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/ssl.rb:77:in `call'
77934b14 | /usr/share/gems/gems/actionpack-6.1.7.6/lib/action_dispatch/middleware/host_authorization.rb:142:in `call'
77934b14 | /usr/share/gems/gems/secure_headers-6.5.0/lib/secure_headers/middleware.rb:11:in `call'
77934b14 | /usr/share/gems/gems/railties-6.1.7.6/lib/rails/engine.rb:539:in `call'
77934b14 | /usr/share/gems/gems/railties-6.1.7.6/lib/rails/railtie.rb:207:in `public_send'
77934b14 | /usr/share/gems/gems/railties-6.1.7.6/lib/rails/railtie.rb:207:in `method_missing'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/urlmap.rb:74:in `block in call'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/urlmap.rb:58:in `each'
77934b14 | /usr/share/gems/gems/rack-2.2.8/lib/rack/urlmap.rb:58:in `call'
77934b14 | /usr/share/gems/gems/puma-6.4.0/lib/puma/configuration.rb:272:in `call'
77934b14 | /usr/share/gems/gems/puma-6.4.0/lib/puma/request.rb:100:in `block in handle_request'
77934b14 | /usr/share/gems/gems/puma-6.4.0/lib/puma/thread_pool.rb:378:in `with_force_shutdown'
77934b14 | /usr/share/gems/gems/puma-6.4.0/lib/puma/request.rb:99:in `handle_request'
77934b14 | /usr/share/gems/gems/puma-6.4.0/lib/puma/server.rb:443:in `process_client'
77934b14 | /usr/share/gems/gems/puma-6.4.0/lib/puma/server.rb:241:in `block in run'
77934b14 | /usr/share/gems/gems/puma-6.4.0/lib/puma/thread_pool.rb:155:in `block in spawn_thread'
77934b14 | /usr/share/gems/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2024-02-16T12:06:03 [I|app|77934b14] Rendered common/500.html.erb within layouts/application (Duration: 3.3ms | Allocations: 1186)
2024-02-16T12:06:03 [I|app|77934b14] Rendered layouts/base.html.erb (Duration: 3.2ms | Allocations: 2609)
2024-02-16T12:06:03 [I|app|77934b14] Rendered layout layouts/application.html.erb (Duration: 9.0ms | Allocations: 4924)
2024-02-16T12:06:03 [I|app|77934b14] Completed 500 Internal Server Error in 277ms (Views: 11.5ms | ActiveRecord: 34.3ms | Allocations: 71460)
Any kind of insight or thoughts on how to remedy this issue would be greatly appreciated.
