At the very end of the foreman installation it fails with the following error message:
/Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[vlt01429.ourcompany.net]: Could not
evaluate: Exception Failed to open TCP connection to vlt01429.ourcompany.net:443 (Connection
refused - connect(2) for "vlt01429.ourcompany.net" port 443) in get request to:
https://vlt01429.ourcompany.net/api/v2/smart_proxies?
search=name=%22vlt01429.ourcompany.net%22
Installer finishes without errors
Foreman 1.20
Katello 3.10
Details below:
tfm-rubygem-hammer_cli_foreman-0.15.1-1.el7.noarch
tfm-rubygem-foreman_docker-4.1.0-2.fm1_20.el7.noarch
rubygem-foreman_maintain-0.3.0-1.el7.noarch
tfm-rubygem-hammer_cli_foreman_bootdisk-0.1.3-7.el7.noarch
foreman-postgresql-1.20.2-1.el7.noarch
tfm-rubygem-hammer_cli_foreman_tasks-0.0.13-1.fm1_20.el7.noarch
foreman-1.20.2-1.el7.noarch
tfm-rubygem-foreman-tasks-0.14.3-1.fm1_20.el7.noarch
vlt01429.ourcompany.net-foreman-proxy-1.0-1.noarch
tfm-rubygem-foreman-tasks-core-0.2.5-2.fm1_20.el7.noarch
tfm-rubygem-hammer_cli_foreman_docker-0.0.4-4.el7.noarch
foreman-release-scl-7-2.el7.noarch
foreman-debug-1.20.2-1.el7.noarch
foreman-installer-1.20.2-1.el7.noarch
foreman-installer-katello-3.10.0-1.el7.noarch
vlt01429.ourcompany.net-foreman-client-1.0-1.noarch
vlt01429.ourcompany.net-foreman-proxy-client-1.0-1.noarch
foreman-cli-1.20.2-1.el7.noarch
foreman-selinux-1.20.2-1.el7.noarch
foreman-proxy-1.20.2-1.el7.noarch
foreman-compute-1.20.2-1.el7.noarch
katello-certs-tools-2.4.0-1.el7.noarch
katello-default-ca-1.0-1.noarch
katello-selinux-3.0.3-1.el7.noarch
After it fails I was able to connect to the port 443 (the authorization is missing though):
[root@vlt01429 ~]# wget https://vlt01429.ourcompany.net/api/v2/smart_proxies?
search=name="vlt01429.ourcompany.net"
--2019-03-21 12:52:33-- https://vlt01429.ourcompany.net/api/v2/smart_proxies?
search=name=vlt01429.ourcompany.net
Resolving vlt01429.ourcompany.net (vlt01429.ourcompany.net)... 10.200.1.66
Connecting to vlt01429.ourcompany.net (vlt01429.ourcompany.net)|10.200.1.66|:443... connected.
HTTP request sent, awaiting response... 401 Unauthorized
Authorization failed.
[root@vlt01429 ~]# foreman-installer --scenario katello --foreman-initial-organization "ourcompany_Playground" --foreman-initial-location "Frankfurt" --foreman-admin-first-name Katello --foreman-admin-last-name Administrator --foreman-admin-username kat-admin --foreman-admin-password 'xxxxxxxxx' --foreman-proxy-tftp false --katello-proxy-url http://proxy.ourcompany.de --katello-proxy-port 3128 --foreman-proxy-bind-host '*' --puppet-server false --puppet-server-ca false --foreman-proxy-puppet false --foreman-proxy-manage-puppet-group false --foreman-proxy-puppetca false --foreman-proxy-content-puppet false --no-enable-puppet --enable-certs --certs-user foreman
Resetting puppet server version param...
/Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[vlt01429.ourcompany.net]: Could not evaluate: Exception Failed to open TCP connection to vlt01429.ourcompany.net:443 (Connection refused - connect(2) for "vlt01429.ourcompany.net" port 443) in get request to: https://vlt01429.ourcompany.net/api/v2/smart_proxies?search=name=%22vlt01429.ourcompany.net%22
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:89:in `rescue in request'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:71:in `request'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:6:in `proxy'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:13:in `id'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_smartproxy/rest_v3.rb:17:in `exists?'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/property/ensure.rb:81:in `retrieve'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type.rb:1070:in `retrieve'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type.rb:1098:in `retrieve_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:302:in `from_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/resource_harness.rb:20:in `evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:257:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:277:in `eval_resource'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:181:in `call'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:181:in `block (2 levels) in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:515:in `block in thinmark'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/benchmark.rb:308:in `realtime'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:514:in `thinmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:181:in `block in evaluate'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:121:in `traverse'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:171:in `evaluate'
/usr/share/gems/gems/kafo-2.1.0/modules/kafo_configure/lib/puppet/parser/functions/add_progress.rb:30:in `evaluate_with_trigger'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:239:in `block (2 levels) in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `block in apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:156:in `with_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:146:in `as_logging_destination'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:237:in `apply'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:186:in `block (2 levels) in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:185:in `block in apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `block in benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:231:in `benchmark'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:184:in `apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:369:in `run_internal'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:237:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:260:in `override'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:211:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:354:in `apply_catalog'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block (2 levels) in main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block in main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:233:in `main'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:174:in `run_command'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `block in run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:663:in `exit_on_fail'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:136:in `run'
/opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:73:in `execute'
/opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
Wrapped exception:
/opt/puppetlabs/puppet/lib/ruby/2.4.0/net/http.rb:906:in `rescue in block in connect'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/net/http.rb:903:in `block in connect'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/timeout.rb:93:in `block in timeout'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/timeout.rb:103:in `timeout'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/net/http.rb:902:in `connect'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/net/http.rb:887:in `do_start'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/net/http.rb:876:in `start'
/opt/puppetlabs/puppet/lib/ruby/2.4.0/net/http.rb:1407:in `request'
/opt/puppetlabs/puppet/lib/ruby/gems/2.4.0/gems/oauth-0.5.1/lib/oauth/consumer.rb:161:in `request'
/usr/share/foreman-installer/modules/foreman/lib/puppet/provider/foreman_resource/rest_v3.rb:76:in `request'
Installing Done [100%] [..........................................................................................................................................................]
yum install -y -q rh-mongodb34-syspaths finished successfully!
