Content/Environment not sync'ing to a Smart Proxy
I have 2 content/environment that are no sync’ing to a Smart Proxy…
Note:
  • Other content/environment are sync’ing ok to this Smart Proxy
  • The 2 content/environment that are not sync’ing to this Smart Proxy are sync’ink ok with 3 other Smart Proxies…
These 2 content/environment should sync to this Smart Proxy
Just upgraded to Foreman 3.2.0 and Katello 4.4.0 on main server + 4 Smart Proxies
I did not have this problem before the upgrade but I don’t understand why only 1 out of 4 smart proxies is affected…
CentOS 7 fully up-to-date to latest.
When I look at the tasks I can see a warning:
Error message: the server returns an error
HTTP status code: 500
Response headers: {"date"=>"Wed, 20 Apr 2022 18:16:11 GMT", "server"=>"gunicorn", "content-type"=>"text/html", "x-frame-options"=>"DENY", "content-length"=>"145", "vary"=>"Cookie", "x-content-type-options"=>"nosniff", "referrer-policy"=>"same-origin", "correlation-id"=>"8e2fe481-ca51-49df-a3a0-a51062bd7f35", "access-control-expose-headers"=>"Correlation-ID", "via"=>"1.1 foremansmartpxy01.local", "connection"=>"close"}
Response body:
<!doctype html>
<html lang="en">
<head>
  <title>Server Error (500)</title>
</head>
<body>
  <h1>Server Error (500)</h1><p></p>
</body>
</html>
[SSL] PEM lib (_ssl.c:4067)[SSL] PEM lib (_ssl.c:4067)[SSL] PEM lib (_ssl.c:4067)[SSL] PEM lib (_ssl.c:4067)[SSL] PEM lib (_ssl.c:4067)Error message: the server returns an error
Response headers: {"date"=>"Wed, 20 Apr 2022 18:16:21 GMT", "server"=>"gunicorn", "content-type"=>"text/html", "x-frame-options"=>"DENY", "content-length"=>"145", "vary"=>"Cookie", "x-content-type-options"=>"nosniff", "referrer-policy"=>"same-origin", "correlation-id"=>"8e2fe481-ca51-49df-a3a0-a51062bd7f35", "access-control-expose-headers"=>"Correlation-ID", "via"=>"1.1 foremansmartpxy01.local", "connection"=>"close"}
Response body:
<!doctype html>
<html lang="en">
<head>
</head>
<body>
</body>
</html>
Response headers: {"date"=>"Wed, 20 Apr 2022 18:16:24 GMT", "server"=>"gunicorn", "content-type"=>"text/html", "x-frame-options"=>"DENY", "content-length"=>"145", "vary"=>"Cookie", "x-content-type-options"=>"nosniff", "referrer-policy"=>"same-origin", "correlation-id"=>"8e2fe481-ca51-49df-a3a0-a51062bd7f35", "access-control-expose-headers"=>"Correlation-ID", "via"=>"1.1 foremansmartpxy01.local", "connection"=>"close"}
Response body:
<!doctype html>
<html lang="en">
<head>
</head>
<body>
</body>
</html>
Backtrace
/opt/theforeman/tfm/root/usr/share/gems/gems/pulp_rpm_client-3.17.4/lib/pulp_rpm_client/api_client.rb:83:in `call_api'
/opt/theforeman/tfm/root/usr/share/gems/gems/pulp_rpm_client-3.17.4/lib/pulp_rpm_client/api/remotes_rpm_api.rb:248:in `list_with_http_info'
/opt/theforeman/tfm/root/usr/share/gems/gems/pulp_rpm_client-3.17.4/lib/pulp_rpm_client/api/remotes_rpm_api.rb:170:in `list'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/services/katello/pulp3/api/core.rb:216:in `remotes_list'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/services/katello/pulp3/repository_mirror.rb:128:in `fetch_remote'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/services/katello/pulp3/repository_mirror.rb:46:in `remote_href'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/services/katello/pulp3/repository_mirror.rb:25:in `refresh_entities'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/services/katello/pulp3/repository.rb:183:in `refresh_mirror_entities'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/katello/capsule_content/refresh_repos.rb:44:in `block in invoke_external_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/relation/delegation.rb:87:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/katello/capsule_content/refresh_repos.rb:37:in `invoke_external_task'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/polling.rb:84:in `initiate_external_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/polling.rb:19:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/cancellable.rb:14:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/pulp3/abstract_async_task.rb:10:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:582:in `block (3 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/stack.rb:27:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware.rb:19:in `pass'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware.rb:32:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/stack.rb:23:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/middleware/remote_action.rb:16:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/middleware/remote_action.rb:40:in `block in as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/models/katello/concerns/user_extensions.rb:21:in `cp_config'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/middleware/remote_action.rb:27:in `as_cp_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/middleware/remote_action.rb:39:in `as_remote_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.4.0.2/app/lib/actions/middleware/remote_action.rb:16:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/rails_executor_wrap.rb:14:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/execution_wrapper.rb:88:in `wrap'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/rails_executor_wrap.rb:13:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/progress.rb:31:in `with_progress_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action/progress.rb:17:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/load_setting_values.rb:20:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_request_id.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_request_id.rb:52:in `restore_current_request_id'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_request_id.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_timezone.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_timezone.rb:44:in `restore_curent_timezone'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_timezone.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_taxonomies.rb:45:in `restore_current_taxonomies'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_taxonomies.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_user.rb:15:in `block in run'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_user.rb:54:in `restore_curent_user'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman-tasks-6.0.1/app/lib/actions/middleware/keep_current_user.rb:15:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/middleware/world.rb:31:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:581:in `block (2 levels) in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:580:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:580:in `block in execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `block in with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `catch'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:483:in `with_error_handling'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:575:in `execute_run'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/action.rb:296:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:18:in `block (2 levels) in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract.rb:167:in `with_meta_calculation'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:17:in `block in execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:32:in `open_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/execution_plan/steps/abstract_flow_step.rb:16:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/director.rb:69:in `execute'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/sidekiq/worker_jobs.rb:11:in `block (2 levels) in perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors.rb:18:in `run_user_code'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/sidekiq/worker_jobs.rb:9:in `block in perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/sidekiq/worker_jobs.rb:25:in `with_telemetry'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/sidekiq/worker_jobs.rb:8:in `perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/dynflow-1.6.4/lib/dynflow/executors/sidekiq/serialization.rb:27:in `perform'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:192:in `execute_job'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:165:in `block (2 levels) in process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:128:in `block in invoke'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/middleware/chain.rb:133:in `invoke'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:164:in `block in process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:137:in `block (6 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:109:in `local'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:136:in `block (5 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq.rb:37:in `block in <module:Sidekiq>'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:132:in `block (4 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:250:in `stats'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:127:in `block (3 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_logger.rb:8:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:126:in `block (2 levels) in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/job_retry.rb:74:in `global'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:125:in `block in dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:48:in `with_context'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/logging.rb:42:in `with_job_hash_context'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:124:in `dispatch'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:163:in `process'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:83:in `process_one'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/processor.rb:71:in `run'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:16:in `watchdog'
/opt/theforeman/tfm/root/usr/share/gems/gems/sidekiq-5.2.7/lib/sidekiq/util.rb:25:in `block in safe_thread'
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
Could that be related to this problem?
Ok same issues as reported here:
On my dodgy Smart Proxy
# cd /tmp
# sudo -u pulp PULP_SETTINGS='/etc/pulp/settings.py' pulpcore-manager datarepair-2327 --dry-run
Remotes with un-encrypted fields: 19
Remotes encrypted multiple times: 11
Finished. (30 remotes fixed)
Remotes with un-encrypted fields: 0
Remotes encrypted multiple times: 0
Back to sync’ing with no issue.
