Conversion of Katello Git Repositories to DEB/RPM Repositories
I am currently working on a project where I need to convert Katello Git repositories into DEB/RPM repositories. My goal is to find an efficient method to perform this conversion so that I can centrally manage both Debian and RPM packages using Katello. I am looking for detailed steps and recommendations on tools or scripts that could facilitate this process.
Thank you in advance for your assistance!
What do you mean by Git repositories? You want to convert the code of Katello itself into an rpm? The packaging team already does that, and I don’t understand what else you may mean here.
You can already manage both Debs and RPMs using Katello – simply enable the deb content type.
What Jeremy said. All of the packages for RPM are here: https://yum.theforeman.org/ but can be accessed with detailed steps from the install guide. For DEB they are here https://deb.theforeman.org/ If you want things right away, there is a nightly folder and rpms that get created each night.
Automating RPM/DEB Releases Download and Integration into Katello/Pulp
Hi everyone,
I think there might have been a misunderstanding in my initial question. Just to clarify, I’m not trying to package Katello itself into RPM/DEB.
What I’m looking to do is automate the process of downloading the latest RPM/DEB releases from multiple Git repositories (such as GitHub, GitLab) and adding them to my local Katello/Pulp repository.
For example, let’s take example-project, which provides RPM and DEB packages in its GitHub/GitLab releases section. Since I don’t necessarily have API access, I need to find a way to regularly check for new versions and integrate them into Katello without manually downloading and uploading each time.
Workflow (Example with example-project)
1. Check the latest release of `example-project`
   ├── Manually visit the releases page or parse the webpage
   ├── Identify the latest `.rpm` and `.deb` versions
   ├── Download them via public links
   └── Skip if the latest version is already present
2. Upload the files to Katello/Pulp
   ├── Use `hammer repository upload-content` to add the new RPM/DEB
   ├── Synchronize and update the content view
   └── Publish so clients can access the latest versions
Steps to achieve this
  1. Manually check or use a script to find new .rpm or .deb releases from the example-project releases page (without API access).
  2. Download the latest available package using a public URL.
  3. Upload it to Katello/Pulp using:
hammer repository upload-content --id <repo_id> --path /path/to/example-project-latest.rpm
  1. Publish the updated content view so clients can access the latest versions.
I was wondering if Katello/Pulp already provides a built-in way to sync these third-party releases without requiring API access? If so, I’d love to learn more about it. Otherwise, I’m planning to set up a scheduled script to handle this, and any advice would be greatly appreciated.
Thanks in advance!
At least to my knowledge, there is no built in way. I tried automating the download of the always latest version of a package from a gitlab repo myself in the past, but without API access, this is a rather complicated task due to how the release pages work.
What might help is that there are stable URLs that always point to the latest release, but then you will still need some way to determin the correct filename, since release artifacts usually contain the filename.
On Gitlab, these links take the form of https://gitlab.com/<username or groupname>/<reponame>/-/releases/permalink/latest/downloads/<filename>, which automatically redirect to the latest release. There is a similar thing for Github, but I do not have the URL for that at hand.
Hope this helps.
It’s really similar as you say, https://github.com/<org>/<repo>/releases/download/latest/<filename>
The filename is the catch though, if this one is always the same you don’t really need the api access, but if you need to find out the version before downloading the artifact, because it’s in the artifact name then it’s really a get the versions json from the api (with credentials) and then download.
Hi, there,
thank you for all answer.
I’m sharing my progress with you
curl -s "https://api.github.com/repos/dunglas/mercure/releases" | jq first | grep rpm | grep amd64
      "name": "mercure_0.18.4_linux_amd64.rpm",
      "browser_download_url": "https://github.com/dunglas/mercure/releases/download/v0.18.4/mercure_0.18.4_linux_amd64.rpm"
I’ll then have to create an RPM repo with the metadata and keep it up to date.
createrepo </path/to/repo>
createrepo --update </path/to/repo>
I take all tips for simplify this process with in next 10 repo git
If you have to do this for every git repo, I think it’s worth spending some time to speed up git source integration (lab or hub or other).
S.Y.L.
[ANNOUNCE] New Ansible Role – git_packages_downloader
Hi everyone :waving_hand:,
I’d like to share a new Ansible role I’ve published:
:bullseye: git_packages_downloader
:package: Available on Ansible Galaxy
:magnifying_glass_tilted_left: What does it do?
This role allows you to automatically fetch and mirror Git-based release packages (e.g. GitHub) into a local RPM repository, filtered by architecture and extension.
It’s designed to be simple, idempotent, and ready for integration with Foreman or standalone Ansible playbooks.
:white_check_mark: Features
  • Supports GitHub as a provider (extensible to others)
  • Filters assets (e.g., amd64, .rpm)
  • Downloads latest release from GitHub
  • Creates a proper local directory for packages
  • Optionally sets SELinux context (httpd_sys_content_t)
  • Runs createrepo if needed
  • Foreman-friendly variable structure (list of dicts)
  • No Foreman hard dependency in the role itself
:hammer_and_wrench: Example usage
git_packages:
  - name: mercure
    source:
      provider: github
      owner: dunglas
      repo: mercure
      arch: amd64
      ext: rpm
    repository:
      base_path: /var/www/html/repos
      mode: "0755"
      owner: apache
      group: apache
      selinux_enable: true
:rocket: [ANNOUNCE] New Ansible Role – git_packages_downloader
I’m excited to share a new Ansible role I’ve developed:
This role automates the process of fetching and mirroring Git-based release packages (e.g., from GitHub) into a local RPM repository. It filters assets by architecture and extension, ensuring that only the relevant packages are downloaded. Designed to be simple and idempotent, it’s ready for integration with Foreman or standalone Ansible playbooks.
  • Downloads the latest release from GitHub
:wrench: Example usage
yaml
CopierModifier
git_packages:
  - name: acme_pkg
    source:
      provider: github
      owner: mipsou
      repo: acme_project
      arch: amd64
      ext: rpm
    repository:
      mode: "0755"
      owner: apache
      group: apache
This role is particularly useful for automating the integration of third-party packages into your infrastructure, especially when direct API access to Git repositories is restricted.
Feel free to check it out on Ansible Galaxy and let me know if you have any questions or feedback!
