Because if I do that - I get: [root@foreman btop]# gpg --keyserver keys.gnupg.net --recv-key 16E90B3FDF65EDE3AA7F323C04EE7237B7D453EC gpg: requesting key B7D453EC from hkp server keys.gnupg.net gpgkeys: HTTP fetch error 6: Could not resolve host: keys.gnupg.net; Unknown error gpg: no valid OpenPGP data found. gpg: Total number processed: 0
I don’t know where to get the correct GPG key for this repo, but I can confirm that the error you are getting most likely means that verification of the downloaded Release file failed with the provided GPG key.
I’ve ran the commands from orcharhino docs and the ones you’ve posted and I cannot reproduce the error.
If you download Release and Release.gpg, you should be able to see which GPG keys are used to sign the Release file when running gpg --verify Release.gpg Release. Where you get the keys from is not important as long as you cross-check the fingerprint.
Finally, you want to export enarmored gpg keys into one file, which you can then upload to Foreman, for example with gpg --armor --export KEY_1_FINGERPRINT KEY_2_FINGERPRINT > /path/to/a/file.txt
To generate the key as keys.gnupg.net does not exist in DNS anymore.
This time, it runs for a few minutes - I see that the disk usage goes up a few GB so it must be pulling down content, but then it stops with a warning as the details say:
I am afraid, the last time this issue was reported, I was told by pulpcore developers, that this has been addressed for pulpcore 3.14, but @Binky is using Katello 4.2, so it should already be solved…
I think that is the one. 1000s is more than 16 minutes, so if it still fails, then there is probably something going on that is not just slow networking…
thanks for confirming It is running on my test proxmox setup with 8GB of RAM allocated, so maybe that is what’s also contributing to the timeouts! Will let you know if I’m successful
@Justin_Sherrill Do you have any ideas how to keep debugging this? It is a pity the error does not tell us what it was trying to download when it ran into the timeout!
I don’t know to what extent it makes sense to keep increasing the timeout. Downloads should not take more than 16 minutes…
I’ve increased it anyway to 10000 to see if it helps I’ve a 80MB fibre connection. Not sure how big an initial Debian 10 repo would be, but I’ve got 500GB allocated which should be plenty enough! Thanks for your help so far - I’m definitely at least a ton further than I was a few hours ago!
Bare in mind that it will take 2h 46min to run into that timeout. If you do run into it, then this is NOT a timeout issue, but a connection times out no matter what issue!
One possible reason would be something blocking connections such as a firewall or http proxy (which it doesn’t look like you’ve configured).
It might helpful to try to curl some file from the debian repo on the foreman/katello server itself? And check if you’ve got an http proxy configured via an env variable, as curl might use that (but pulp/katello would not).
so it’s taken about 1hr to get to 41% - and the disk space usage has definitely gone up by over 20GBs so I think it’s getting there, let you know if it is successful!
