I have been just dropping a file pub.conf into the /etc/httpd/conf.d/ directory.
The file is tiny it looks like:
Alias /pub /var/www/html/pub
<Location /pub>
PassengerEnabled off
Options +FollowSymLinks +Indexes
Require all granted
The problem is that any time the foreman-installer gets run it removes the file.
What is the correct way to enable /pub and not have to put a file back every time?
This seems to be the same for Foreman version 1.16 thru 1.20 and probably even older.
Thanks for any direction or help!
