Guys,
I have a new installation of Foreman (v.1.9.2) in a new Ubuntu 14.04.03 and
everything is working great.
I have installed the plugin from Greg (foreman_default_hostgroup) to have
some automation on the grouping field and followed the instructions from
the Foreman's plugins page.
But my nodes are not being grouped at all.
I wrote a default_hostgroup.yaml with the config as follows:
:default_hostgroup:
:facts_map:
"Workstations/Location1":
"network_local_area_connection": "182.35.18.0"
"Workstations/Location2":
"network_local_area_connection": "182.35.20.0"
"Default":
"hostname": ".*"
I kept it simple so I could focus on making it to work but no luck.
This is what I have done so far:
Tried to use a even simpler fact like:
:default_hostgroup:
:facts_map:
“Linux”:
“osfamily”: “Debian”
“lsbdistcodename”: “trusty”
Path of yaml file:
~/foreman/config/settings.plugins.d/default_hostgroup.yaml
Changed the settings force_hostgroup_match to true and
force_hostgroup_match_only_new to false.
Content of /var/log/foreman/production.log:
2015-10-23T14:30:42 [app] [I] Started POST “/api/hosts/facts” for
192.168.10.10 at 2015-10-23 14:30:42 +0900
2015-10-23T14:30:42 [app] [I] Processing by Api::V2::HostsController#facts
as JSON
2015-10-23T14:30:42 [app] [I] Parameters: {“facts”=>"[FILTERED]",
“name”=>“myserver.my.domain.com”, “certname”=>“myserver.my.domain.com”,
“apiv”=>“v2”, :host=>{“name”=>“myserver.my.domain.com”, “certname”=>“
myserver.my.domain.com”}}
2015-10-23T14:30:43 [app] [I] Import facts for 'myserver.my.domain.com’
completed. Added: 0, Updated: 5, Deleted 0 facts
2015-10-23T14:30:43 [app] [W] DefaultHostgroupMatch: Could not load
default_hostgroup map from settings, check config.
2015-10-23T14:30:43 [app] [I] Completed 201 Created in 408.4ms (Views:
8.0ms | ActiveRecord: 0.0ms)
2015-10-23T14:30:43 [app] [I] Started GET "/node/myserver.my.domain.com?format=yml"
for 192.168.10.10 at 2015-10-23 14:30:43 +0900
2015-10-23T14:30:43 [app] [I] Processing by HostsController#externalNodes
as YML
2015-10-23T14:30:43 [app] [I] Parameters: {“name”=>“myserver.my.domain.com
2015-10-23T14:30:43 [app] [I] Rendered text template (0.0ms)
2015-10-23T14:30:43 [app] [I] Completed 200 OK in 124.5ms (Views: 0.8ms |
ActiveRecord: 12.0ms)
Would you guys have any ideas?
Thx
> Path of yaml file:
~foreman, right? i.e. /usr/share/foreman/config/settings.plugins.d/
> 2015-10-23T14:30:42 [app] [I] Started POST "/api/hosts/facts" for
> Api::V2::HostsController#facts as JSON
> 2015-10-23T14:30:42 [app] [I] Parameters: {"facts"=>"[FILTERED]",
> "name"=>"myserver.my.domain.com",
> "certname"=>"|myserver.my.domain.com|", "apiv"=>"v2",
> :host=>{"name"=>"|myserver.my.domain.com|",
> "certname"=>"|myserver.my.domain.com|"}}
> '|myserver.my.domain.com|' completed. Added: 0, Updated: 5, Deleted 0 facts
This error suggests it's not picking up the settings at all.
Have you restarted Foreman since adding/changing the file? Note that by
default Foreman's running under Apache, so "service apache2 restart" or
"touch ~foreman/tmp/restart.txt" to do it - don't restart the "foreman"
service.
On 23/10/15 06:58, Eric Ohtake wrote:
Dominic Cleal
dominic@cleal.org
Dominic,
As always, you nailed it!
I misread the manual and where I read
~foreman/config/settings.plugins.d/default_hostgroup.yaml I tought I would
have to create these folders into the root user folder.
That's why I came with ~/
The correct path to put the yaml file, as you said, is:
Now I have everything working fine!
Also thank you about the restart tip.
You are a life saver.
Thanks!
> > Path of yaml file:
> facts
> > *2015-10-23T14:30:43 [app] [W] DefaultHostgroupMatch: Could not load
> > default_hostgroup map from settings, check config.*
> service.
> Dominic Cleal
> dom...@cleal.org
Ah okay, no problem.
That documentation was probably written before we had the easier path of
/etc/foreman/plugins/ (/usr is now a symlink to it), so I've updated it,
which should be clearer.
Dominic Cleal
dominic@cleal.org
On 23/10/15 11:22, Eric Ohtake wrote:
Dominic,
would have to create these folders into the root user folder.
That’s why I came with
~*/*foreman/config/settings.plugins.d/default_hostgroup.yaml
Thanks!
> Path of yaml file:
> "name"=>"myserver.my.domain.com <http://myserver.my.domain.com>",
<http://myserver.my.domain.com>|", "apiv"=>"v2",
<http://myserver.my.domain.com>|"}}
> '|myserver.my.domain.com <http://myserver.my.domain.com>|'
that by
service.
Dominic Cleal
dom...@cleal.org <javascript:>
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com
That is great. In the name of the community, thanks for the doc update.
> Dominic Cleal
> dom...@cleal.org
> > Dominic,
> > Thanks!
> > > Path of yaml file:
> > > "name"=>"myserver.my.domain.com ",
> > |", "apiv"=>"v2",
> > > '|myserver.my.domain.com |'
> load
> > that by
> or
> "foreman"
> > service.
> > Dominic Cleal
> > dom...@cleal.org
> > You received this message because you are subscribed to the Google
> > Groups "Foreman users" group.
> > an email to foreman-user...@googlegroups.com
> > <mailto:foreman-users+unsubscribe@googlegroups.com >.
> > To post to this group, send email to forema...@googlegroups.com
> > <mailto:forema...@googlegroups.com >.
> > Visit this group at http://groups.google.com/group/foreman-users.
> > For more options, visit https://groups.google.com/d/optout.
