and part of the STIG requires these directories to be on different partitions or logical volumes and I am new to this and would like any help in regards of how to accomplish this. I assume editing the partition table but am unsure of what to get rid of or what to add.
Thank you very much for this. If it isn’t a bother may I ask how you install additional packages? It doesn’t seem to find the extra needed packages from the kickstart, so I just download them post install with some yum commands but I think that only works because the VM gets connected to the internet but they won’t have internet access in the future so it must be through foreman to get these packages.
It seems the finish template will download those packages after everything is done? But I think for this to work I need to have the package list in the kickstart file not the kickstart finish. But when I add it to the kickstart file it doesn’t seem to find these packages. and when I try to add another repo like this
