I am creating one foreman plugin and my plugin creates additional tables
into the foreman database.
Some of tables using primary key (eg: Host :id) as foreign key in to my
plugins table(Eg: Xyz :host_id).
So, now i want to write relationship between foreman tables and my plugin
tables into the Model otherwise if i will not write these line then i am
getting exception about foreign key present when somebody deletes host from
foreman
Eg
and see it in action in foreman_salt, among others:
(loaded from an initialiser in engine.rb)
> plugin tables into the Model otherwise if i will not write these line
> then i am getting exception about foreign key present when somebody
> deletes host from foreman
> Eg
> has_many :xyz, :foreign_key => :host_id, :dependent => :destroy
> above line will destroy all related foreign keys entry whenever
> respective primary key deleted from main table.
> But , in this case i will have to modify foreman code which i not good...
> So, is there any way where we can define such relationships into our
> custom plugin code .
Sorry, if i misunderstood you or might be i am not expert in term of plugin
development .
If somebody deletes host from All Hosts Menu item then after i am getting
error about the key is present in custom foreman table.
I want to establish the relationship in my custom model like whenever if
some body delete hosts from All hosts menu item of foreman then he/she can
able to delete and my table entries should delete too.
So, what should i write in my model or extension where it will
automatically delete host .
error:
Warning!ERROR: update or delete on table "hosts" violates foreign key
constraint "xyz_host_id_fk" on table "xyz" DETAIL: Key (id)=(12) is still
referenced from table "xyz"
Aditya
> > Eg
> good...
> Yes, you can extend a model from a plugin and add statements such as
> has_many at the class level.
> Usually you do this inside the "included" block in a Rails concern, a
> standard module/mixin that can be added to Host::Managed:
> http://projects.theforeman.org/projects/foreman/wiki/How_to_Create_a_Plugin#Extend-Foreman-Model-Add-instance-or-class-methods
> https://github.com/theforeman/foreman_salt/blob/4.0.1/app/models/foreman_salt/concerns/host_managed_extensions.rb#L7
> https://github.com/theforeman/foreman_salt/blob/4.0.1/lib/foreman_salt/extensions.rb#L9-L10
> Dominic Cleal
> dom...@cleal.org
I think you had the has_many correct already. You need to create a
concern, like the one in the wiki link or the host_managed_extensions.rb
link and then add a line to the engine.rb to load it.
If that's not working, please share the code and error message you're
getting.
> tables
> to my
> > Eg
> good...
> Dominic Cleal
> dom...@cleal.org
> plugin development .
> getting error about the key is present in custom foreman table.
> can able to delete and my table entries should delete too.
Thanks Alot Dominic for your valuable help… you saved lots of effort of
mine.
I will really forward to help you in future to contribute more in this
google group.
Thanks alot once again.
> > On Friday, November 20, 2015 at 4:14:13 PM UTC+5:30, Dominic Cleal > wrote:
> > tables
> > to my
> line
> somebody
> > > Eg
> > good...
> our
> a
> http://projects.theforeman.org/projects/foreman/wiki/How_to_Create_a_Plugin#Extend-Foreman-Model-Add-instance-or-class-methods>
> https://github.com/theforeman/foreman_salt/blob/4.0.1/app/models/foreman_salt/concerns/host_managed_extensions.rb#L7>
> https://github.com/theforeman/foreman_salt/blob/4.0.1/lib/foreman_salt/extensions.rb#L9-L10>
> > Dominic Cleal
> > dom...@cleal.org
> getting.
> Dominic Cleal
> dom...@cleal.org
