DDNS compatible with Foreman DHCP management?
I just ran into an odd issue that I'm hoping has a simple solution. I
recently enabled DDNS management on my DHCP server that is managed by
Foreman.
ddns-updates on;
ddns-update-style interim;
update-static-leases on;
use-host-decl-names on;
Key from bind
include "/etc/rndc.key";
zone DOMAIN.TLD. {
primary 192.168.202.254;
key rndc-key;
zone 168.192.in-addr.arpa. {
key rndc-key;
This worked great when I would add "dhcp::host" Puppet resources, but I
just tried adding a host named "admin.DOMAIN.TLD" via Foreman and found the
DNS records created was "admin.DOMAIN.TLD.DOMAIN.TLD". This ended up
causing errors like this when provisioning completed. The host never
completed the build after 4 or 5 attempts so I tried to cancel the build
which failed and this is what the logs printed:
Started GET "/unattended/built?token=af784c4c-56c6-49ef-a09a-956084badfd6"
for 192.168.200.5 at 2015-04-07 12:54:51 -0500
Processing by UnattendedController#built as /
Parameters: {"token"=>"af784c4c-56c6-49ef-a09a-956084badfd6"}
Found admin.DOMAIN.TLD
unattended: admin.DOMAIN.TLD is Built!
DNS PTR Records 192.168.200.5/admin.DOMAIN.TLD.DOMAIN.TLD already exists
Completed 409 Conflict in 949ms (ActiveRecord: 13.3ms)
And
Started GET "/hosts/admin.DOMAIN.TLD/cancelBuild" for <OMIT> at 2015-04-07
12:54:39 -0500
Processing by HostsController#cancelBuild as HTML
Parameters: {"id"=>"admin.DOMAIN.TLD"}
Failed to save: IP address has already been taken, Conflict DNS PTR Records
Redirected to https://foreman.DOMAIN.TLD/hosts/admin.DOMAIN.TLD
Completed 302 Found in 958ms (ActiveRecord: 16.8ms)
My guess the reason DDNS works for a "dhcp::host" and not a DHCP entry
added by foreman-proxy has to do with the host-name option set.
Example of something created by dhcp::host
host pdu9b {
hardware ethernet 00:C0:B7:CD:F9:D7;
fixed-address 192.168.206.78;
ddns-hostname "pdu9b";
option vendor-encapsulated-options 01:04:31:41:50:43;
Example of entries in /var/lib/dhcpd/dhcpd.leases
host admin.DOMAIN.TLD {
dynamic;
hardware ethernet 00:01:a4:aa:3a:4c;
fixed-address 192.168.200.5;
supersede host-name = "admin.DOMAIN.TLD";
This is somewhat dated instance of Foreman, 1.6.0, on CentOS 6.5.
I'm curious if this is a misconfiguration or if there are inherit issues
with managing both DNS and DHCP using Foreman and also allowing DHCP to do
DDNS. So far the DNS + DHCP management via Foreman and Foreman Proxy have
worked great, but some things can't be added to Foreman to create a DNS
record, like PDUs. So for those items I relied on "dhcp::host" and wanted
an "automatic" way to get those entries into DNS.
  • Trey
I think it's because you omit the dot at the end of your fqdn : admin.DOMAIN
.TLD*. <- See the trailing dot.*
DNS work this way at least.
··· 2015-04-07 20:27 GMT+02:00 treydock :
I just ran into an odd issue that I’m hoping has a simple solution. I
Foreman.
ddns-updates on;
Key from bind
include “/etc/rndc.key”;
zone DOMAIN.TLD. {
key rndc-key;
key rndc-key;
This worked great when I would add “dhcp::host” Puppet resources, but I
just tried adding a host named “admin.DOMAIN.TLD” via Foreman and found the
DNS records created was “admin.DOMAIN.TLD.DOMAIN.TLD”. This ended up
Started GET “/unattended/built?token=af784c4c-56c6-49ef-a09a-956084badfd6”
Parameters: {“token”=>“af784c4c-56c6-49ef-a09a-956084badfd6”}
And
Started GET “/hosts/admin.DOMAIN.TLD/cancelBuild” for at 2015-04-07
12:54:39 -0500
Parameters: {“id”=>“admin.DOMAIN.TLD”}
My guess the reason DDNS works for a “dhcp::host” and not a DHCP entry
host pdu9b {
ddns-hostname “pdu9b”;
dynamic;
supersede host-name = “admin.DOMAIN.TLD”;
I’m curious if this is a misconfiguration or if there are inherit issues
worked great, but some things can’t be added to Foreman to create a DNS
record, like PDUs. So for those items I relied on “dhcp::host” and wanted
an “automatic” way to get those entries into DNS.
  • Trey
“Foreman users” group.
The value 'admin.DOMAIN.TLD' value in dhcpd.leases was set by the
foreman-proxy, so anything wrong with the values would be a bug with proxy
I think.
··· On Wed, Apr 8, 2015 at 9:46 AM, claude juif wrote:
I think it’s because you omit the dot at the end of your fqdn : admin.
DOMAIN.TLD*. ← See the trailing dot.*
2015-04-07 20:27 GMT+02:00 treydock treydock@gmail.com:
Foreman.
ddns-updates on;
Key from bind
zone DOMAIN.TLD. {
key rndc-key;
key rndc-key;
Started GET
“/unattended/built?token=af784c4c-56c6-49ef-a09a-956084badfd6” for
And
07 12:54:39 -0500
host pdu9b {
dynamic;
  • Trey
https://groups.google.com/d/topic/foreman-users/giJtX4il6A8/unsubscribe.
I mean just name the host admin.
··· 2015-04-08 22:51 GMT+02:00 Trey Dockendorf :
The value ‘admin.DOMAIN.TLD’ value in dhcpd.leases was set by the
I think.
Foreman.
ddns-updates on;
Key from bind
zone DOMAIN.TLD. {
key rndc-key;
key rndc-key;
Started GET
And
07 12:54:39 -0500
host pdu9b {
dynamic;
  • Trey
an email to foreman-users+unsubscribe@googlegroups.com.
