At CfgMgmtCamp 2019, Wim gave us a talk on the pipeline that he’s created which involves ALL THE THINGS! So we thought it’d be fun to bring you that talk as a Deep Dive
Here’s Wim’s own abstract for the talk:
“Management of Katello can be challenging: there are just so many components
to take care of! Configuration is often changed manually (via the webui or
using hammer), and I wanted to investigate if its possible to apply a
‘regular config management’ workflow to Katello. Using cloud-init, forklift
and foreman-ansible-modules, we’re able to quickly spawn up a fully
customized Katello instance (and schedule regular executions of the
playbooks using AWX).”
