Hi
I provisioned a foreman installer. i would like to deploy centos on a bare metal device. please provide a complete setup on foreman ui to build os.
Regards,
Bhaskar
Hi
Regards,
Bhaskar
foreman tftp server showing false can you help how to make it true. enabled in setting tftp.yml file as true.
Hey @foreman1
You can use “foreman-installer” to configure networking services. See Configuring network services in Provisioning hosts.
getting client side error while booting from pxe network PXE-E23: client received tftp error from server
enabled true using below
foreman-installer --foreman-proxy-tftp true
its getting enabled but from UI side its showing as “TFTP server as false”
check tftp logs:
# journalctl -u tftp -f
Mai 24 19:26:15 <user> in.tftpd[26138]: Client ::ffff:192.168.2.104 finished boot/rocky-linux-imLv796i67R9-initrd.img
Mai 24 19:41:00 <user> systemd[1]: tftp.service: Deactivated successfully.
Mai 26 10:16:08 <user> systemd[1]: Started Tftp Server.
Mai 26 10:16:08 <user> in.tftpd[147746]: Client ::ffff:192.168.2.104 finished pxelinux.0
also check the proxies logs and try to temp. disable your firewall
also check your tftp configuration.
i think the initial install can also log some valuable infos.
but i think the tftp is just misconfigured so proxy wont start that service
